Stephen NZ Posted May 18, 2021 Share Posted May 18, 2021 (edited) I wonder if there is a data source that can tell you want locomotives were allocated where in the past. For modern locomotives it's not a problem because I can find a prototype photo of a locomotive in a location. However for steam locomotives (other than presently preserved ones), finding photos of the right type of locomotive in the right prefecture is tougher - often the photos aren't clear enough to see the number. I'm am trying to model a Hoikkaido location and don't want to chose a number plate for my locomotives that was based in Kyushu or somewhere. Edited May 18, 2021 by Stephen NZ Link to comment
Yavaris Forge Posted May 18, 2021 Share Posted May 18, 2021 For steam locomotives, there is this nice website which lists a lot of info on (most) Japanese steam locos ever in service: http://d51498.com/db/ Although I don't know if that site will load for you, I usually use a Japanese VPN to access such sites. 2 2 Link to comment
Stephen NZ Posted May 18, 2021 Author Share Posted May 18, 2021 14 hours ago, Yavaris Forge said: For steam locomotives, there is this nice website which lists a lot of info on (most) Japanese steam locos ever in service: http://d51498.com/db/ Although I don't know if that site will load for you, I usually use a Japanese VPN to access such sites. Yes, I tried and it said that access was forbidden. Thanks anyway. Link to comment
gavino200 Posted May 19, 2021 Share Posted May 19, 2021 1 hour ago, Stephen NZ said: Yes, I tried and it said that access was forbidden. Thanks anyway. You can sign up for a free trial of a VPN. Many of them offer one. Get the information you want and then cancel. Link to comment
Madsing Posted May 19, 2021 Share Posted May 19, 2021 I use TunnelBear (https://www.tunnelbear.com). Free 500MB per month. Enough for quite a number of things. 1 Link to comment
Szdfan Posted May 19, 2021 Share Posted May 19, 2021 On 5/17/2021 at 7:04 PM, Stephen NZ said: I wonder if there is a data source that can tell you want locomotives were allocated where in the past. For modern locomotives it's not a problem because I can find a prototype photo of a locomotive in a location. However for steam locomotives (other than presently preserved ones), finding photos of the right type of locomotive in the right prefecture is tougher - often the photos aren't clear enough to see the number. I'm am trying to model a Hoikkaido location and don't want to chose a number plate for my locomotives that was based in Kyushu or somewhere. Where in Hokkaido is your location? Link to comment
Stephen NZ Posted May 19, 2021 Author Share Posted May 19, 2021 59 minutes ago, Szdfan said: Where in Hokkaido is your location? Niinai on the old closed Karikachi section of Nemuro Line between Ochiai and Shintoku. I'm not obsessive about prototype (I reimagine it never closed, so i can run modern rolling stock too). I just want to try to use numbers of engines that it would not be silly to think may have operated in Central Hokkaido. 1 Link to comment
Szdfan Posted May 19, 2021 Share Posted May 19, 2021 1 hour ago, Stephen NZ said: Niinai on the old closed Karikachi section of Nemuro Line between Ochiai and Shintoku. I'm not obsessive about prototype (I reimagine it never closed, so i can run modern rolling stock too). I just want to try to use numbers of engines that it would not be silly to think may have operated in Central Hokkaido. I’ve been interested in the locomotive depot at Minami-Wakkanai, but am still in a very early state of research 1 Link to comment
Stephen NZ Posted May 29, 2021 Author Share Posted May 29, 2021 On 5/19/2021 at 10:50 AM, Stephen NZ said: Yes, I tried and it said that access was forbidden. Thanks anyway. Tried on a different brower and it works now. It's exactly what I was looking for. Thanks very much for the guidance! 1 Link to comment
Stephen NZ Posted August 9, 2021 Author Share Posted August 9, 2021 Further to my question back in May, I have been using D51498.com since then and found it really useful. However, it seems to have been down a lot in the last couple of weeks. Is anyone else having the same problem and, if so, know what's going on? Link to comment
cteno4 Posted August 10, 2021 Share Posted August 10, 2021 Working here in us tonight. jeff Link to comment
Kiha66 Posted August 10, 2021 Share Posted August 10, 2021 Interesting, it isn't loading for me. I've had a few JP sites do that in the past, including the site where the signature trains come from. Link to comment
Stephen NZ Posted September 3, 2021 Author Share Posted September 3, 2021 Sorry but this site was working well until a month ago and seems to be down still. Does anyone know what is happening with this site? It's a great resource when it is working? Does anyone know the administrator of it to reach out to? Link to comment
Yavaris Forge Posted September 3, 2021 Share Posted September 3, 2021 Still works for me... Link to comment
Stephen NZ Posted September 3, 2021 Author Share Posted September 3, 2021 Can ask what your using to access it in terms of browser or proxy service then because it was working no problem for me but not at all recently. Link to comment
roadstar_na6 Posted September 3, 2021 Share Posted September 3, 2021 It usually works fine from both my iPhone and my laptop with Chrome or Firefox without any proxies/VPNs Link to comment
