How many blocks for my station?
gavino200
I have a dilemma. I'm working on two small projects in parallel. One is learning about block detection on a small practice layout. The other is building my station as a module to be added to my layout when my train room is finished. Problem - I'm making my way slowly through the basics of block detection and automation and don't expect to have an in-depth concept of how it works for some time. However, I'd like to continue work on my station as it's a crucial part of my layout.
Can anyone take a look at my station plans and tell me how I might want to block it? I don't mind adding too many blocks. I'd prefer to add too many than too few.
I understand this will depend on what I want to do. Right now I want it to be as versatile as possible. I definitely want to be able to do accurate precise stops. Perhaps music/announcements. Definitely signalling. Perhaps other things I haven't thought about yet.
These are some pictures of the basic plan.
West end. Each white card is a platform.
tvCVZel.jpg?1
East end.
Anyrail view
Platforms. Not sure this is relevant for the blocks
The length is 13 N700 cars, or an E5 and one car of an E6
Edited by gavino200
It depends a bit on how you want to occupy the tracks on the station. The most obvious would be 1 train per platform at most, in which case you only need 1 block per platform. If you want to be able to store 2 shorter trains on 1 track alongside a platform, you'd need to split that track into 2 blocks. Longer trains can then still use the platform, they'll just occupy both blocks.
For precise stopping, that can be a bitt difficult. If you have a long train, it'll occupy the entire length of the platform, so in that case you can add a stop section near the end of the platform. However, if you have a shorter train, that'll then also stop at the same stop section, which means it's not centered alongside the platform. You might not want that of course, and even so, with software you can always have long trains stop at the stop section, and shorter trains to center themselves.
Signalling might be an issue, I don't know of any software that supports Japanese signalling by default. Some programs allow you to create custom signals, but of course you'll have to know how the Japanese signalling system works. Since you've been using iTrain, there's a fair chance that if you can explain the Japanese signalling system, the developer will implement it.
There is also hardware such as the OC32 (http://www.vpeb.nl/english/solutions/accessories/oc32/) which allows you to hook up LEDs and have them working together. Again, by default this thing doesn't support Japanese signals, but it is programmable. I believe you can then basically map signals in iTrain to drive a signal through the OC32. Of course, in iTrain it won't look like a Japanese signal, but on the layout you can make it look however you want.
I don't know anything about Japanese signals, so I'm not sure if it's possible, but considering I want to add signals to my layout as well, this is something I've been wanting to look into. At some point ... 🙂
I guess I jumped the gun by assuming that there are working Japanese signals on the market. Apart from the automatic crossing signals, I'm not seeing any. If I have to use European signals that wouldn't be the worst thing. It would still look cool. Also, I don't really need it to be absolutely prototypical. If they change as the trains go round that would probably be enough for me. But I do think that working signals would look very cool.
Tomix has working Japanese signals, but I believe they have all sorts of electronics in them, so no idea how / if they work with DCC. Here's one with 4 lights https://www.1999.co.jp/eng/10160426. They're rather rough, should be fairly easy making these yourself, especially since you don't need all the electronics apart from some LEDs for the lights.
Also, seems the Japanese system is based on the Swiss system, so it that might be usable in iTrain.
I don't know anything about Japanese signaling but they also make 5 color ones
https://www.1999.co.jp/eng/10160419
https://www.1999.co.jp/eng/10034520
The 4 color doesn't have it but the 5 color ones actually have an image in the "other images" that shows the progression.
Anyway, the comment I wanted to make was this is maybe where a 3d printer of some sort becomes useful...   (Not having any myself)
Agree. This could be the perfect thing for a crowd-sourced JNS project!
There are signals with 2, 3, 4, 5 and 6 lights, but for most layouts, the 5 and 6 are probably not very useful. Wikipedia has a pretty decent English article about the signalling system actually https://en.wikipedia.org/wiki/Japanese_railway_signals
The Tomix signals have a pre-defined progression, due to the electronics in them. I guess they could be re-purposed for DCC use, but they're a bit expensive for that. You really only need some LEDs, some resistors, and a (3D printed?) signal housing. And then of course some sort of accessory decoder that can drive the LEDs.
I could do some experimenting with 3D printing and the like. I don't know the dimensions of the signals though, so I'd have to see if I can find those somewhere.
I can pony up for one of the signals available on the market, if you want to use it to "draw inspiration from".
Nah, that's okay, I can order some signals if needed as well, that'd give me a good idea of how they look, although the Tomix ones definitely look out of scale. I do have some Tomix form signals though, so I might be able to compare those with some pictures, and base measurements for light signals on that. I also believe some people on the forum have been looking into this and made some working signals, but I can't remember exactly.
I'll try to make a little circuit board first with just a few white LEDs on them, and hook those up to an OC32. That way I can see if I can program the OC32 to do Japanese signals, and check how I can control them through iTrain.
tvCVZel.jpg?1
East end.
Anyrail view
There you go!
From your pictures and comments (also some of my assumptions), I designed how the signalling (includes blocks) should be made if you layout was for real (using UK signalling practice, sort of...). That is, it gives you an idea of how things should work and this design would need to be modified for a model layout. About the picture below, I added the signals so you can see (more or less) what train movements could be achieved.
  • highlighted in yellow = Insulated rail joints, these mark the block sections (thinking more about "train detection")
  • Shunt (or auxiliary) movements from 17 and 19 signals must end at 13 and 15 signals. If you want to run directly (without stopping), signals 17 and 19 need to be modified and/or and additional signal should be added where the "X" is place (orange colour).
  • Bidirectional lines
  • To make it Japanese, you could start by replacing signals (from UK to JPN) then finding more about JPN signalling
  • I found the video below about a Numeric Route Indicator, it could not be JPN practice but check by yourself.
NX
Edited by NX:
note: overlap sections not shown for simplicity's sake
Hmm, it would be good to know who's working on this. I bet @cteno4 would know. Perhaps, @chadbag too. I've seen on @Madsing's Shin-Yukari website that he's had experience placing LEDs in Kato traffic lights, though I think It was a static display. Still, there might me some useful pearls to be gathered.
Cool beans. The OC32 is a signal control DCC peripheral? Like the Digikeijs DR4018?
2 minutes ago, chadbag said:
I am not doing anything with working signals.  I am interested but have enough other things right now.
Yeah, I know. I just figured you might know who was.
Sorry, you’re right there have been a few folks chatting here or there on doing more prototypical signals here and there but I don’t recall specially who. @Madsing was working on his signaling system and a connector system to the signal from the layout. I think he was using premade signals. I’m sure he will chime in.
Hello,
I am still working on the signals (is anything ever finished in this hobby?). This is the current status:
1. Trains
I am using Tomix signals, but I only use the signals themselves (I know, it's a waste). The signals can easily be detached from the base (the piece of track with the sensor and the electronics). Tomix provides two-, three-, four- and five-aspect signals (they even have two kinds of four-aspect signals). The nice thing is that they all use the same four pin connector with the same pinout. This is a photo of the three-aspect signal's PCB:
The three LEDs are at the top (with the resistors in between) and the connector is at the bottom. I have reversed engineered the signals; the schematics are here:
TomixSignals.pdf
I couldn’t find the exact four-pin male connector corresponding to the signals but using standard 1.27mm pitch headers works.
https://www.aliexpress.com/item/32706990813.html
I cut four pins and solder them on this base board:
https://www.aliexpress.com/item/32395360741.html
This is the result:
To control the signals using the Z21 (and Rocrail), I have designed a DCC controller based on an Arduino Nano. It works well (still working on the software). The latest version is compatible with two-, three-, four- and five-aspect signals, but I am still trying to figure out how DCC commands would work with five-aspect signals. This is a photo of the controller. It supports up to 10 two-, three-, four- or five-aspect Tomix signals. I can share the design files and the code if anyone is interested.
My understanding of the most common Japanese signals is that they basically indicate how many blocks are free in the route ahead. They turn red when a train passes them, then will turn yellow ("different kinds of yellow") and finally green as the train moves further away along the route. The sequences are detailed on the Tomix web site.
I have captured that behaviour in this video:
The standard Tomix signals have a single sensor in their base track. A train passing triggers the red aspect, then the signal shows the following aspects based on an internal timer.
On my layout, I am using sensors and the position of switches to trigger the various aspects. This is not the default mode in Rocrail, but that can be programmed using “Actions”. As my layout is very small, I don’t have routes long enough to justify using four- or five-aspect signals, Since I still wanted to use these, I am working on a mix of sensors and timers to simulate that (still WIP, the signals shown above have been connected last week)
2. Trams
I use a mix of Tomix two-aspect signals and Kato 23-214 traffic signals kit-bashed to look like departure signals from the Toyama station. They are fitted with small LEDs and connected to the same DCC controller described above.
3. Road
I use Kato 23-214 traffic signals fitted with small LEDs. Their color doesn’t change (except for the flashing pedestrian crossing signal).
4. Other notes
I have tried purchasing cheap(er) signal from AliExpress, but they don’t look good. Many are just oversized.
I have purchased the Tomix 0742 (https://www.1999.co.jp/eng/10405410) in the past, this was probably a spare part, but it didn’t look as good as the model currently available, and it is sold out for a long time anyway.
  • Thanks 2
OC32 is a pretty universal bit of gear. It can control signals, lights, motors, servos and more. It also has inputs and can also be used as occupancy detector, and control functions based on inputs.
It does require programming though, and a lot of layout control software doesn't really support it directly, so it definitely has some limits.
I'd be mostly interesting in the physical dimensions of the signals. They look rather straightforward, so making some 3D models would be relatively easy.
Things like the ladder would probably need to be etched or scratch built from brass rods to get any sort of detail, the pole itself can be a brass tube so you can run wires through it. So it's really only the enclosure for the LEDs, and those detail parts around the pole that would need to be printed.
I'm working on a very similar project, also using Itrain (except mine is a 4 platform terminus, at present i have been working on the basis of using English style signalling (mostly 3 aspect) as I understand how it should function (and more importantly there are signals available to use), my station uses 3 feedbacks per platform, (mostly becuase the station splits into 3 parts, but also so that a short feedback is provided at the country end, to allow permissive working, and a feedback is at the buffer end to shut off the arrival jingle when a train has 'mostly' arrived
  • gavino200 changed the title to How many blocks for my station? Signals and Arduino.
I'm going to do a little modeling work on my station this weekend and will revisit the issue of where to put my signals. I'm also going to start learning how to control the signals.
I'll use this post to collect sites and videos related to signaling. I like the idea of an arduino project, partly because I'm learning about arduinos anyway and enjoying it. I'll need to look at the capabilities of the Digikeijs system as I know it can drive signals directly. No point reinventing the wheel if I already have this capability at my fingertips. In any case learning how different people are achieving this can't hurt.
I'll add to this as I discover worthwhile references
Websites
Videos
The significance of this just hit me. Three blocks per platform works perfectly for me. My station is broken into three modules. West, central, and east. They'll each have to be wired separately, so it makes sense to give each it's own feedback. I'll run with that unless I find some other logic.
I'm still interested in installing IR sensors if necessary. They're much cheaper than I expected and not so difficult to use. Digikeijs has a unit that controls them, but likely I'll try to find a way to Aruduino them. Just because 😜
On 2/13/2021 at 3:33 PM, NX: said:
There you go!
NX
I'm going back to this now trying to digest the information. I realize there's really no short cut to signalling. I'm just going to have to school myself about how it works. At the moment I'm trying to estimate how many signals I'll need to buy and what kind.
Really, I don't need them to be super prototypical. I mainly just want them to "look cool" and bring some life to the layout. But it's going to be a lot of work so I might as well invest the time in learning what prototypical is, even if I don't follow it exactly.
In playing with my trains I've never cared about direction. All tracks were open to traffic from both directions. I just drove trains anywhere I wanted. But I think real trains don't work that way. Lines are more like lanes of traffic on a road. One way only. So the signals point one way. I have to give some thought about whether I want to restrict my rail play to this constraint. Probably yes. Since I'm automating anyway, it's not a big step. Otherwise the signals will look dumb shining in the wrong direction.
Likely I'll have to revisit my layout design to make sure I can make it work. Since learning about automation there are probably a few other changes I'll want to make.
Awesome. This should help then.
Those swiss lights do look very cool. But super complicated. That's way more detail than I need. I think all I need is a simple three light block occupancy system.
Now to decide where to put them.  I guess one at the beginning of every block.
