Custom Via Duct
inobu
Needed a via duct that would span 3 tracks without the walls. I wanted it to be open so you could see the trains.
Used some of what Tomix uses in their design but adopted it for the Kato piers. I need to do some touch up work
and color match the Piers.
  On 1/18/2021 at 10:51 PM, inobu said:
I need to do some touch up work and color match the Piers.
Expand
Why not just paint both the Kato piers and your piers too? The Kato piers look quite plasticy as they are.
Expand
I actually tried to color match the resin. You can see how the first half are gray and the last 4 are white. I
should have used the off color resin instead of the white. Color matching the resin is a pain its a lot of trial and error
which I did not have time for.
We'll see how it goes painting them.
