Tomix 5512 DU202 Cab Controller
The technical term for the "tram brake" operation is "straight" air brakes. The operator takes a "bite" of air in the apply position, then goes back to the lap position to hold that pressure. The art is in knowing how much air pressure is needed for a smooth stop in a specified distance. As Bill said, the operator will usually go briefly to release to vent a little pressure off and then go back to lap, to smooth the final stages of the stop. The other style is called "self-lapping" brakes, where the more you go to one side with the handle, the more braking action you get. The straight air brakes came first, and the self-lapping design was a big improvement. The next big improvement was the safety feature for train brakes, where the control line pressure actually keeps each car's brakes off. Each car has a reservoir tank to apply its own brakes. That way, if a break occurs in the trainline air piping or hoses, the brakes come on instead of losing all air and having no brakes.
So the DU202 brake action is based on a self-lapping brake system. One thing I'm not clear on is whether the model train gradually loses speed with no power and no braking applied, like a real train would lose momentum, or whether it just coasts on indefinitely.
Rich K.
Bill, Rich, thanks for the great information!!
With no throttle, and no brakes, the train will eventually coast to a stop. Throttle, brake, and rolling friction elements are all modeled independently in the throttle, so you can get some interesting interactions: Full throttle will make the train just begin to move under moderate brake pressure; at high speeds, the train will coast to a lower speed when the throttle is set on notch up from neutral, etc.
Here`s a prototype with very similar controls, now in a museum. Its a Series 183 Asusa with lots of bells and whistles to play with.
Mr Frosty
I recently picked up a Gaugemaster DS. This is a twin track controller with switchable "simulation mode". This provides Individual control of power/coasting & braking using a separate regulator and brake. These can be had second hand from ebay for about £30 - £40, which compares quite favourably to the new price of £160.
Manual
http://www.gaugemaster.com/instructions/ds.pdf
ebay
http://www.ebay.co.uk/itm/Gaugemaster-DS-Twin-Track-Controller-Simulation-And-Brake-12v-N-OO-Gauge-/320897447620?pt=UK_Trains_Railway_Models&hash=item4ab6fa76c4
