GDorsett Posted May 3, 2020 Share Posted May 3, 2020 I have been told that Rivarossi motours will draw more power than a decoder can provide. Is this true or can I put a decoder into a Rivarossi model without changing the motour? For reference, I have an A.T.S.F. Type 2-10-2 in B&O with a Vanderbilt tender and it has the old motour mounted right in the cab. I can swap in an Athearn motour if I need to, but I'd like to avoid motour swaps for now if I can as it runs really good as it is right now. Here:s the model: Link to comment
brill27mcb Posted May 3, 2020 Share Posted May 3, 2020 They make high-amperage motors for O scale trains, so some appropriate decoder ought to be possible. Especially with that big tender to put it in... Rich K. 1 Link to comment
inobu Posted May 4, 2020 Share Posted May 4, 2020 I think the issue stems from the condition of the motor and gears. I did one a few years ago and noticed the grease in the gears hardened. The engine was from the late 90's. Check the linkage as well make sure they are not bent or anything. Without the motor connected to the engine it should move freely. The other problem area was the drive shafts. They were like tubes and break easily so be careful. This was a shelf queen that a guy wanted DCC installed. Sound wise its dialed in believe it or not its has a single sugar cube speaker. Inobu Link to comment
GDorsett Posted May 4, 2020 Author Share Posted May 4, 2020 (edited) This loco does not have any issues what-so-ever. I cleaned it up and lubricated it properly after I purchased it. And I will be putting sound in it I can find the right files. this one is quite enough. There is nothing to make any noise since there isn't any gearing. Edited May 4, 2020 by GDorsett Link to comment
chadbag Posted May 4, 2020 Share Posted May 4, 2020 23 hours ago, brill27mcb said: They make high-amperage motors for O scale trains, so some appropriate decoder ought to be possible. Especially with that big tender to put it in... Rich K. I assume you mean high amperage decoders... Link to comment
inobu Posted May 5, 2020 Share Posted May 5, 2020 6 hours ago, GDorsett said: This loco does not have any issues what-so-ever. I cleaned it up and lubricated it properly after I purchased it. And I will be putting sound in it I can find the right files. this one is quite enough. There is nothing to make any noise since there isn't any gearing. If that's the case you should be ok. Just look at the wheels to determine the mileage on the motor. If the wheels are worn then pay attention to how it runs. Just like buying a high mileage car. The high current draw is going to be from binding, load or motor core issues. Inobu 1 Link to comment
GDorsett Posted May 5, 2020 Author Share Posted May 5, 2020 Wheels on this one are not worn at all. It's in remarkably good shape for it's age other than the missing bell, headlight lense, and hand rail. Link to comment
inobu Posted May 5, 2020 Share Posted May 5, 2020 If you do the baffle right you can get really good sound. The sound in the video is recorded with my iphone. No sound manipulation or anything. Haven't heard from the guy that I did it for. Next time I come across one I'm going to keep it. Inobu Link to comment
