KATO Standard Power Pack Help
AhmadKane
AhmadKane
Normally when you plug the input to the power pack, the light is gonna turn on.
Somehow mine doesn't. I want to fix the thing. Can anyone help?
So the power pack works but the green led is not lit? You need to replace the led.
Open up the power pack. It is just two wire stems than need to be soldered. Or check the soldering it still good and not cracked.
Edited by katoftw
