shadowtiger25 Posted April 8, 2020 Share Posted April 8, 2020 Well, all the local cubs are closed, and I'm itching to be able to run trains. I have wanted to do this for a while since I now have a spare room I have never been able to find a roommate for, so I'm going to build a "small" HO scale layout with Kato Unitrack following their Fox Meadow Valley design build up the frame work for the layout today. Although it needs more structural support, but I'm out of wood and screws for now HO-plan-Fox-Meadow.pdf 1 Link to comment
cteno4 Posted April 8, 2020 Share Posted April 8, 2020 Great, it’s a start! Thinking of wheels at all to easily move around to work on all sides? Or will it be living away from the walls? nice little plan, good room left for structures. jeff Link to comment
shadowtiger25 Posted April 8, 2020 Author Share Posted April 8, 2020 it doesn't really have space to move as there is only 6 inches left over on the 10 foot sides, a bit of a mistake on my side, but that's how we learn.😅 the picture doesn't show it but there is a closet in that room just off the side on the left that eats up space. next I want to put in a couple of support bars and put extruded polystyrene on top my plan was for it to be 41 inches tall so it would be eye level from an office chair at half height. I will probably make the scenery in sections and put it on finished since space is an issue. Link to comment
cteno4 Posted April 8, 2020 Share Posted April 8, 2020 Whoops, but you can just move back and forth to have against the wall on one end and a foot of room at the other which Is around the minimum to work in. 3’ reach in from sides will be a long reach, but ho so a bit easier with parts twice as big. Step stools with a frame to lean against may help some but do be careful reaching out 3’ not to loose your balance and not to over strain your back. I’ve been lucky with a strong back (only tweaked it slightly a couple of time doing really stupid lifts) but I have cramped it up badly working out arms extended like that for longer times. scenery panels are a good idea just have to figure out a way to drop them in place and remove when needed out in the middle jeff Link to comment
shadowtiger25 Posted April 8, 2020 Author Share Posted April 8, 2020 on the 6 foot sides there is at least 4 feet of clearance in the room so moving back and forth is no problem Link to comment
shadowtiger25 Posted April 16, 2020 Author Share Posted April 16, 2020 Well, the bench work is now almost complete, and now all I need is the foam-board to put on top of it. It would be finished but my drill ran out of power... Also, the guy at the store cut my wood to the wrong size, and I had to use a spacer, and cut an extra inch from the other boards. Also I ordered all of the track that I needed, minus the peices that one of my club members donated to me from his very dusty store room Also, I striped the crap out of this screw trying to get it in.. 1 Link to comment
katoftw Posted April 16, 2020 Share Posted April 16, 2020 If you make all the bracing skinny side up. They will be 5x stronger. 1 Link to comment
inobu Posted April 16, 2020 Share Posted April 16, 2020 (edited) 6x10 is a larger layout, you have to design that size of layout. Bench work in modules. It helps in space utilization. https://www.sieversbenchwork.com/modulelayout.html Modules gives you natural shelf space along with crawl space. I'm not saying to buy it but model your build after it. The cost is in the labor to cut the wood. Oh, you need to drill pilot holes. Inobu Edited April 16, 2020 by inobu Link to comment
shadowtiger25 Posted April 16, 2020 Author Share Posted April 16, 2020 (edited) 4 hours ago, inobu said: Oh, you need to drill pilot holes. Inobu I did drill holes, the drill is a cheep one thats a bit underpowered, and it was running low on battery power at the time Also, I'm going with a track plan that kato made. I will look at those next time I plan one, but this one is only going to last a couple of years 11 hours ago, katoftw said: If you make all the bracing skinny side up. They will be 5x stronger. I had thought about that, but I decided to do it like that to help hold the foam board. I dont really plan on putting a lot of scenery in. Its my first layout in a place I'm probably only going to live in for like 2 more years while in college. I plan on moving after my BA degree Edited April 16, 2020 by shadowtiger25 Link to comment
inobu Posted April 16, 2020 Share Posted April 16, 2020 This is a good tool. The demo allows you to place 50 pieces of track. The full access is $60.00 Its about spending your Hobby Dollars wisely...and not making costly mistakes. A Kato HO switch is $55. So it would be worth giving up 1 switch on your layout for this program. The program can save you a lot of headache and lost money on mistakes. On top of that you can design your layout based on your needs. https://www.anyrail.com/en/download Do everything on paper first. Its easier and cheaper to erase than tear down and buy again. When its on paper you can price everything out as well. Mcmaster Carr Inobu Link to comment
inobu Posted April 16, 2020 Share Posted April 16, 2020 You will be surprised with all the hidden issues that pop up. Being in WV the humidity will cause the wood to expand and contract making the screw connection loosen up. The center will sag over time. Hobby Dollars. This was 15 years ago. The layout is long gone but I reused the cabinets in my shop today. Spend wisely. Good Luck Inobu 2 Link to comment
shadowtiger25 Posted April 24, 2020 Author Share Posted April 24, 2020 laid out most of the track, forgot about 1 pack of curves, but I will get those soon Link to comment
ranger10178 Posted April 24, 2020 Share Posted April 24, 2020 Looking good! Shame about missing track... I'm forever forgetting to order one little thing here and there... Link to comment
shadowtiger25 Posted April 24, 2020 Author Share Posted April 24, 2020 8 minutes ago, ranger10178 said: Looking good! Shame about missing track... I'm forever forgetting to order one little thing here and there... at least its only one 4 pack I need. some of this track was given to me and those curves just happen to be part of what was Link to comment
shadowtiger25 Posted May 20, 2020 Author Share Posted May 20, 2020 Never gave any updates, but I have been working on it I redid the top placing down plywood then gluing the foam on top, and adding foam under the track to raise it up. using homemade sclupter mold I am starting to build up the land form in areas I dont plan n having buildings. I want to order the buildings, but shipping from japan is still up in the air. 5 Link to comment
