Kiran Posted January 4, 2020 Author Share Posted January 4, 2020 Progress. Meeting with a woodworker on Monday and taking all my track samples and curves. As I build modules/sections and laying my track, it also occurred to me that I should research block detection and automation down the line. I think my primary use case for block detection is to stop trains from bumping into each other. There are tons of threads on the forum but all they do is confuse me :). At this stage, as I build modules and lay the track, I want to be able to drop in some sort of an occupancy sensor in the module to be activated / used later. I also don't think it makes sense to have a single module be a block (16 car shinkansen/16 car Calidonian sleeper+loco) and so it should be possible to combine a few sensors to become a block. I have NCE and prefer to stick to it because the controller design is a little more blind friendly. Any recommendations that work with NCE and Unitrak combo would be best. NCE does have the BD20 and the way I understand it, it will trigger as soon as anything is drawing power from the rails. https://ncedcc.zendesk.com/hc/en-us/articles/201254549-BD20-Block-Detector As a crude solution, I used the littleBits proximity sensor with a beeper to figure out if a train is occupying a section and it sort of works OK with single track but struggles a bit with double track. https://littlebits.com/products/proximity-sensor. They even have an mp3 player that I can use to play station announcements if I wanted. 1 Link to comment
Kiran Posted January 11, 2020 Author Share Posted January 11, 2020 Any suggestions on block detection sensors? See my previous post for details Link to comment
Kiran Posted May 18, 2020 Author Share Posted May 18, 2020 I am finally making some progress. I was going to work with a woodworker but he didn't have the time and kept pushing back. So I decided to try Master Piece Modules (masterpiecemodules.com) and their fully assembled 24" x 48" modules which are mainly designed for Freemo. I received a couple of them and I think they can work. I have to use custom Unitrack or even cut some pieces because I am not sure if I can make 1220mm with standard Unitrack pieces. But this is an OK compromise. I still haven't figured out block detection. 1 Link to comment
Kiha66 Posted May 18, 2020 Share Posted May 18, 2020 (edited) Kato unitrak runs on a 62mm increments. So 19 long straight pieces will be 1216mm, or 4 mm short. If you put two S64 straight tracks at some point in the module in place of a 124mm track, that should add the extra mm you need to equal 1220. Sounds like a fun project! Edited May 18, 2020 by Kiha66 1 Link to comment
Kiran Posted May 18, 2020 Author Share Posted May 18, 2020 17 minutes ago, Kiha66 said: Kato unitrak runs on a 62mm increments. So 19 long straight pieces will be 1216mm, or 4 mm short. If you put two S64 straight tracks at some point in the module in place of a 124mm track, that should add the extra mm you need to equal 1220. Sounds like a fun project! Actually 62*19 = 1178 which leaves me with 42mm. Link to comment
Kiha66 Posted May 18, 2020 Share Posted May 18, 2020 Woops! I did 64*19 rather than 62. However in kato 20-091 Short Track Assortment they include a 45.5 mm piece, which would allow a less than 2mm overhang at the end of the module. This could work well, as it would allow for any movement of the module while not leaving a large gap. Link to comment
cteno4 Posted May 18, 2020 Share Posted May 18, 2020 If you want to be perfect it’s pretty easy to just cut out a bit of roadbed you need to reduce it by and then clip the rails off flush. jeff Link to comment
paolo Posted May 18, 2020 Share Posted May 18, 2020 1 hour ago, Kiran said: I still haven't figured out block detection. I'm using Digikeijs equipment for my DCC layout and they've been great (and they're cheap). I have the DR5000 command station connected via LocoNet to four DR4088LN-CS (2R) feedback modules and two DR4018 decoders (used together with DR4101 modules) for the KATO #4 turnouts. You can have 16 feedbacks connected to one DR4088 and 8 turnouts to one DR4018. I'm using iTrain to manage the layout. If you need more info, I'll be happy to help. Link to comment
inobu Posted May 20, 2020 Share Posted May 20, 2020 On 5/17/2020 at 9:28 PM, Kiran said: I am finally making some progress. I was going to work with a woodworker but he didn't have the time and kept pushing back. So I decided to try Master Piece Modules (masterpiecemodules.com) and their fully assembled 24" x 48" modules which are mainly designed for Freemo. I received a couple of them and I think they can work. I have to use custom Unitrack or even cut some pieces because I am not sure if I can make 1220mm with standard Unitrack pieces. But this is an OK compromise. I still haven't figured out block detection. To make a 1220mm straight you need the following 3 248 millimeter track 1 186 millimeter track 1 124 millimeter track 2 64 millimeter track 1 38 millimeter track Kato 20-092 Inobu Link to comment
Kiran Posted June 10, 2020 Author Share Posted June 10, 2020 On 5/19/2020 at 10:09 PM, inobu said: To make a 1220mm straight you need the following 3 248 millimeter track 1 186 millimeter track 1 124 millimeter track 2 64 millimeter track 1 38 millimeter track Kato 20-092 Inobu Thanks Inobu. That certainly works although I might end up with a few 33mm pieces. I was also looking at the 78-108 expansion track piece 20-050 but I am thinking it might look out of place on the module. Link to comment
inobu Posted June 10, 2020 Share Posted June 10, 2020 They come in handy, I have an assorted box of them they make life easy. Inobu . Link to comment
