broken power bogie clip
GiantRoboJustin
GiantRoboJustin
Crap! Managed to snap one of the clips that hold the bogie to the frame while re-assembling my Kato EF30. Was being really careful too cause plastic clips make me paranoid...First time it's happened to me, and weirdly on a loco that I haven't had apart much, so I'm guessing it might've just been some kind of fluke with the plastic.
The loco still runs okay, but wants to lean out when turning right...
I checked for replacements on HS just in case I need them, but they're sold clean out. I did find replacements available on ebay thought, but not for cheap of course, lol (but maybe still worth it?)
Anyways, anyone ever had this happen and been able to fix/remedy? Or is replacement pretty much the only good option?
GiantRoboJustin
My housemate will be in Japan for the next three weeks visiting family. If Kato does in fact still have them, maybe I can have it shipped to her grandma's place in Tokyo. Though the lack of thumbnail pic and description in the listing makes me wonder if it's actually in stock, or just a page that hasn't been fully updated yet...
Also when I search for the part on Kato Japan's main page, it tells me there's 0 search results found
The ones on ebay are $28 +$6 shipping, which I suppose isn't too terrible, especially considering the locos now seem to be going for $90-$120. Plus it'd probably only save me about $10 to get them in Japan...
I thought about trying to glue it, but there's not much surface area to make use of. I could probably cut a thin piece of plastic to use as a brace to reinforce it, but the more I think about it, that might end up being more trouble than it's worth, and might not even work
So I might just bite the bullet on this one...plus it could be worse, at least the parts are available
GiantRoboJustin
Actually after looking at it a bit more, I decided to at least try gluing it, and I think it worked 🙂
The truck feels just as steady in the frame as the other one now, and the loco doesn't appear to be leaning to one side anymore
GiantRoboJustin
I did notice these trucks felt a bit harder to push in than most I've worked on. I wonder if the clips are wider, or the slot narrower than other models...
