Jimbo Posted April 24, 2019 Share Posted April 24, 2019 I won a E81 off e bay, its like new an by the looks of it never run,, of course the paper work is in Japanese,, its missing the lower plate to mount the coupler, Ive done some searching an cant come up with anything?? The seller stated he was going to chance the couplings, I guess the seller lost the mount an gave up?? lol I cant read Japanese !!! an there is no real part number that I can tell?? Thanks for any info, Link to comment
railsquid Posted April 24, 2019 Share Posted April 24, 2019 Model number? Replacement coupling mounts (actually the entire "skirt" area below the cabs) are available. 1 Link to comment
Jimbo Posted April 24, 2019 Author Share Posted April 24, 2019 Ha Thanks I need to re learn my words I guess!!! Yes I finally found something but sold out in two different places also called a debris deflector ?? Link to comment
Gryphr Posted April 24, 2019 Share Posted April 24, 2019 (edited) The part number for Kato's Skirt+Coupler Assemblys should be a "C3" added to the model number, i.e. if your EF81 is model number 3066-1 it would be part number 3066-1C3. "Debris Deflector" seems to be a bit of a literal translation of "Skirt" but it is possibly the same part. Edited April 24, 2019 by Gryphr 1 Link to comment
katoftw Posted April 24, 2019 Share Posted April 24, 2019 If you have the paperwork as you say, you don't need to read Japanese. You just need to look at the diagrams of all the parts and below are the part number for that part. The part numbers are in roman, so you'll have no issue reading them. Link to comment
Jimbo Posted April 24, 2019 Author Share Posted April 24, 2019 9 hours ago, railsquid said: Model number? Replacement coupling mounts (actually the entire "skirt" area below the cabs) are available. 3021-1 Link to comment
katoftw Posted April 24, 2019 Share Posted April 24, 2019 (edited) sure it aint 3066-1? I see no EF81s as 3021-x listed on the kato website edit// actually i did find it. it is an old model long been terminated. Edited April 24, 2019 by katoftw Link to comment
katoftw Posted April 24, 2019 Share Posted April 24, 2019 http://ngage-figure-saint-seiya-mobilesuit.blog.jp/archives/2979212.html I found this website. i compared the coupler and skirt to the 3066-x variant. and while the lower sections are the same, the inner and upper sections are different and would need modifying. https://aucview.aucfan.com/yahoo/m322745576/ https://aucview.aucfan.com/yahoo/349550374/ http://kunnpuu238.blog.fc2.com/blog-entry-272.html Link to comment
railsquid Posted April 24, 2019 Share Posted April 24, 2019 Correct. As it happens I have this exact same model with a similar issue and have already acquired the equivalent 3066 replacement parts, will see if I can do something with them and will report back. FWIW replacement pantographs for this model are also no longer available, but current Kato EH500 ones can be used as a replacement. Link to comment
Jimbo Posted April 25, 2019 Author Share Posted April 25, 2019 well here it is 3021-2 for what I paid with the shipping it was a steal,, 1 Link to comment
railsquid Posted April 25, 2019 Share Posted April 25, 2019 Aha, exactly the same problem mine has. These are the replacement parts I purchased: Kato EF81 coupling assembly replacement by Rail Squid, on Flickr The upper grey part is slightly different (the modern version has a magnet to hold train boards in place) but the black part which holds the coupling in place can be removed and fits just fine into the old model: Kato EF81 coupling assembly replacement by Rail Squid, on Flickr FYI the real EF81-95 is still in service, I saw it yesterday. 2 Link to comment
railsquid Posted April 25, 2019 Share Posted April 25, 2019 54 minutes ago, railsquid said: The upper grey part is slightly different (the modern version has a magnet to hold train boards in place) but the black part which holds the coupling in place can be removed and fits just fine into the old model: Kato EF81 coupling assembly replacement by Rail Squid, on Flickr Ummm, unfortunately while the black part clips in fine, it appears to be slightly longer than the old version and the bottom is way too low, reaching almost to the rails, meaning it's prone to getting stuck on trackwork, particularly points :(. Some modification might be needed... Link to comment
Jimbo Posted April 25, 2019 Author Share Posted April 25, 2019 Thanks I have a set coming from Japan,, My E bay seller there found a set an will do a buy it now for me,, Link to comment
Jimbo Posted April 28, 2019 Author Share Posted April 28, 2019 the e bay seller got me a set of those an did a buy it now for me,, so it should be shipped out on Monday my time,, will see how it works out?? 1 Link to comment
