Martijn Meerts Posted February 23 Author Share Posted February 23 Not been a lot of visual progress since the last post. I was ill a few days, and generally just feeling rather tired most days. However, I did manage to go up to the attic and run some trains if nothing else. I managed to configure and speed measure some more locomotives and did some setup changes in iTrain. At some point I have 5 locomotives running on the local line, going between the yard and the local station. While things were running, I worked on the wiring of the express and shinkansen lines. Most of that is not completed and I just need to add the actual occupancy detector. I may need to move the one for the local line a little bit to make some extra space, but that's easy enough. I'll likely add the occupancy detector in the coming days, which means that for the first time ever, trains can run up the helix to the shinkansen line. For the express line, I still need to install some servos before I can run trains there as well. I have also started adding some bit of foam which will eventually be the scenery. Nothing is glued in place yet, since I'm not sure where to go with the scenery just yet. I also need a little more practice with the various hot wire cutting tools I have before I can thing about shaping the foam. I should probably also get some more rock casting molds so I have something to work off of. Finally, I did also mark the first cross section of the 2nd section for cutting. I'm just wondering if I should use the jigsaw to try and accurately cut it, or do a more rougher cut, and then use a router to accurately recreate the contours of the connection cross section of the first section. Of course, I don't have a router, so I would need to get one first 🙂 Finally, I've been watching a bunch of woodworking videos lately, for some reason Youtube started recommending me those. It's making me look into possible isolating my garage and build a bit of a small workshop / storage space there. Of course, the garage is a bit of a mess at the moment (it's a recurring theme in my house I guess...), and worse, the ceiling uses asbestos boards. Those I will need to have removed by a specialist company. I'm also thinking of building some custom storage cabinets / shelves in the small guest / storage room. Once the attic starts filling up more with layout, I'll need to move some stuff down to this room... 9 Link to comment
cteno4 Posted February 25 Share Posted February 25 Wooo hooo! Go for it martijn, you need a woodshop, it’s a whole nother hobby to dump money into and accumulate more toys! Actually dont need a huge space for a nice little shop if you plan it out well and make everything as mobile as possible. Jeff Link to comment
Martijn Meerts Posted February 25 Author Share Posted February 25 Well, the accumulation of new toys has already started 😄 But yeah, won't be able to build anything big. Definitely no space for the bigger tools you usually see in woodworking videos. The garage isn't very big to start with, and with the insulation added, it'll even get a bit smaller. I'll need to insulate it from the inside, so likely just a vapour barrier, studding and something like Rockwool insulation. I also still need space for a couple of bicycles and other bits and pieces. Before that though, there's a lot of old junk in the garage at the moment, so that has to go first. Something to do during spring I guess. Link to comment
cteno4 Posted February 25 Share Posted February 25 Talk to your local insulator. Foam board and spray foam can be quite compact for the R value, but it is a plastic, not eco material. Cover over with like 12mm ply. Some love to have tons of pegboard to put tools on, ive always hated that myself and am a tool chest user for tools, but thats a very personal choice. Any overhead space not in use like a rafter space you can use for lighter storage area or place to store hanging bikes? Ive been adding large shelves just over my height around the shop walls and over windows for more storage boxes of stuff i dont use often. The only really big space tool is the table saw. But it’s a very central tool to a lot of wood working. There are other work arounds, but they are a whole hobby in itself. But you can fix a smaller table saw with folding side and outfeed tables or use folding roller stands so it can be compact when not in use with bigger pieces of wood. They also make decent work spaces having a nice heavy metal table top, but of course using it and working on a project on it isnt the best thing to attempt! I love my table saw and it’s really the workhorse of the shop. There are alternative ways of cutting with a circular saw and various bench jigs, but i find them tedious myself. I do have a panel jig to cross cut larger ply pieces easier with a small circular saw. Next is drill press in amount of use. Then followed by sander, Planer, and joiner and then band saw and router table. I find next to the table saw i end up sing the drill press a lot all the time. I tend to like to use screws over nails and dowels and such as well for connection as well as bolts and threaded inserts. All of which need more precise drilling than you can do with a hand drill well. Luckily they dont take up a huge space. The new direct drive ones are awesome and are even more compact, but expensive right now [they should come down in price as i expect they will eventually take over most nicer shops with time thier performance is so much better]. A nice belt and disc sander is always very handy and does ot take up much space and can even be just clamped to the bench when in use. Planer i find really handy as i make most all my own dimentional lumber out of larger boards and ply wood. Ripping on a good table saw with fence grips [little wheels that hold the wood firmly against the fence as you feed it] gives you pretty good parallel cuts and they dont really need to be run thru a joiner so i just run each cut side thru the planer and it makes very nice clean dimentional lumber that can be spot on width. Small to medium sized planers can be put away, they are a bit bulky and heavy but can just be plopped onto a folding work table or bench for use and put away in a cabinet when not in use. Joiner is nice to get edges very flat if a big curvy for one reason or another or if it has any divits in it. Band saw is handy for more free form cutting. You can of course do this decently with a godd hand held jig saw with some practice and care. You can also resaw thin pieces of board on a bandsaw, but that requires a larger marching and special wide blades. Router table is handy if you get into shaping edges. Hand routers can do a lot on finished pieces but not so easy on strip material where the router table is handy to feed stock thru. You can get small portable ones that you just pop your hand router into. A small handheld edge router can be pretty cheap and when used with bearing guide bits you can do a ton without a table. Dust handler is essential from the get go. Both to suck dust from each machine in use and also one to just filter all the stuff that will end up in the air and end up coating everything in the shop if not well cleaned out [even then you get a film that needs cleaning now and then[. Folding work tables are great for a small shop as you just open them up when needed for more bench space. They unfold like a sawhorse and then have wings that fold up to give you like 2’x3’ area to put a bench power tool on or your project. Many have some sort of a clamping/vise system built in. Some you can lock more than one together for larger temporary bench. They are not as sturdy as a good traditional workbench, but good enough for most purposes and fold away to little space when not in use. There are a ton of youtube videos of folks building very compact power tool stations and workbench system. If tools are put on good roll arounds you can use the bases for storage and keep most of the toolls rolled up into a line on the wall and just pull out the one you need to use as you use them or toll them outside for big use. But i see some folks just going down the rabbit hole on these systems pouring a ton of time and effort into them which is fine if you are using the shop full time, but for part time you can easily find short cuts. I have a lot of my big bench tools on old craftsman tool chests so i can pack a ton of storage below the tool and it’s mostly all prebuilt. They are not perfect on size and shape always but close enough and pretty heavy duty. For the hand power tools Ive moved to almost all rechargable battery ones. Pict a brand and stick with it so you can share batteries and it’s great to be able to just grab a tool and use it and not fiddle with power cords and such. The power of the brushless motors and batteries these days makes them all more than powerful enough to do anything really. Most are pretty compact these days so you can get a large number of them in a few storage drawers. Batteries are great then for emergency power for lights and recharging cell phones and such, great twofer. I went with the budget Ryobi brand like 30 years ago because of the value and my budget at the time, but I’ve never been disappointed by them. Nothing has broken or worn out on any of them [and i have a lot of them] and quality is quite good. Nicer brands are a bit higher quality and a bit beefier, but ive never found the Ryobis lacking at all and they are usually almost half the price, which means i pickup a new power tool for any job i need it for to have then for the future and thru bundles and sales ive ended up with a big pile of batteries. If i were doing construction and on site i would maybe use one of the fancier brands as tools get beat up fast there, but e cheers jeff Link to comment
Martijn Meerts Posted February 25 Author Share Posted February 25 Remember that this is a European sized garage, that has just enough space for a single European size car 😄 What I was thinking, is use 1 wall for a workbench with space for a mitre saw, and then cabinets below the workbench, as well as above the workbench. The opposite wall would then probably be for storage cabinets and for storing folding work tables and the like. I would love to have more space, but I would have to find something to rent, which currently is next to impossible near where I live. I will still have to get plywood cut at the hardware store (or, more likely a wood specialist store if I do end up doing more woodworking). I'll just have to make sure to add a centimeter to all the measurements, and then do the final cuts myself. Most places where you can have plywood cut to your specifications have rather high tolerances. When my cordless drill pretty much died not long ago, I went and looked at several brands for a new cordless drill and overal system. The old drill didn't have a battery system, so the batteries couldn't be used for anything else, and getting new batteries was impossible. Towards the end I was lucky to get like half an hour of battery life out of the 2 batteries I had. At some point the chuck develop a gigantic amount of play though, so it was just getting annoying to use. After a bunch of research, and checking availability, I ended up with a Festool cordless drill. It's an expensive brand, but some online shops have sales quite regularly. I picked up a T 18+3 drill in a set with charger and 2 batteries with about 40% off during a sale. I've used it quite a lot for building the layout, and it's just a lot more pleasant to use compared to the old one. Since then I also picked up a Festool jigsaw (my old one tended to wander, and was a pain to keep straight), as well as 1 of their dust extractors. With the dust extractor hooked up to the jigsaw, there's hardly any dust at all, just a tiny bit of sawdust on the floor right below where you're cutting. I've actually been cutting contours in the 12mm plywood for the layout up on the attic, and I get more dust from the parrot than from cutting wood 😄 There's a few other tools on my wish list, but I'll only get them if and when I need them. Either way, doing any work on the garage is going to take a while. There's a large old dresser in there which has started falling apart, so I need to cut that apart to be able to get rid of it. There's also a metal frame that was used for an old layout which also needs to be cut up. And finally there's a bunch of junk stacked up which I removed from the crawlspace under the house. The previous owners had used the crawlspace to "store" some stuff, which I only found out about when I had the crawlspace insulated, and had to go down there to remove all that stuff... Anyway, got a little more done on the layout, cut some more bits of foam and worked on lining up the shinkansen and express tracks going from the helix to the first scenic section. It's really rather fiddly since when I made the helix I wasn't as careful with measurements as I am these days. I also 3D printed up several servo harnesses so I can more easily mount them next to the 3 remaining turnouts on the helix. I'll work on installing those the coming days most likely. So there's several fiddly things to do now, which doesn't help the motivation. But I'll get there ... Eventually ... Link to comment
Martijn Meerts Posted March 10 Author Share Posted March 10 Not a lot of progress again, still not in the best shape after having been ill a few weeks ago. I did got some more foam cut, and ended up destroying 1 of my hot wire knife thingies. I think I was a bit impatient and tried to push it a bit too much. Initially it just bent a little bit, so I bent it back so it was straight again. But with the next cut it snapped completely. I'll pick up a new one at some point. Other than that, I quickly did a mockup of some trains on the various lines of the layout, just to get a quick and general idea of how things would look with the rough scenery in place. These are the shinkansen and express lines. The shinkansen line will enter a tunnel just a little left of the middle of the section, whereas the express line will continue a bit further before entering a tunnel. Urban line with some steam. This will become a simple station with a center passing track / freight track. Express line, showing the really wide curve. Quite like the look of this, even though you'll never really see it like this once everything's in place 🙂 I have also been slowly working on a Greenmax engine shed. The idea is that is a more modern extension to an older steam terminal. While the kit does look decent enough, there's a lot of preparation to do. There's a lot of little nubs and whatnot from the molds, and while they are all on the inside, I want to add details to the inside as well, so I need to remove all those. The plastic is also fairly thin, so I need to add something like card stock on the inside to block any interior lights I'll be adding. Finally, also been making some progress on the brass kits. I've been folding and soldering the wheel inserts to make it look like the train has spoked wheels. This is really rather fiddly, but all in all not terrible. Of course, with 1 more kit now almost done, I just had to go and order about 7 new kits.. Picked up several of the Usui pass locomotives, including 4 ED42s (not all motorised) to do a prototypical train. I keep telling myself not to get new kits, but hey 😄 3 Link to comment
Martijn Meerts Posted March 16 Author Share Posted March 16 Since I'm still not quite able to do much of the heavier physical stuff (like moving the segments around and getting things ready to cut more wood), I decided to finally try out the small sandblaster I bought quite a while ago. According to the documentation, my airbrush compressor shouldn't have enough pressure to operate the sandblaster, but it turned out to work just fine. I picked up some glass beads to use as material rather than the included blasting medium, since the included stuff is actually toxic. First quick test. The bonnet on the right side of the picture was sandblasted, very clear difference. I tried this little bit just in a cardboard box, but the glass beads were going all over the place, so there was no way I could do the entire model. So, I turned the cardboard box into a really quick and dirty blasting cabin. It works surprisingly well actually 😄 I guess it could be one of my first woodworking projects, build a portable blasting cabin with some light built in. This is the entire model blasted. If you look closely there's some bulging going on on the sides and the roof. I'm not sure if it's because the pressure was too high, or if I held the sandblaster to close to the model. I did manage to fix it, but there are some visible marks. I don't really mind that, considering I want the models to look used, so some dents and such just add character (and they're a lot easier to add on these brass kits 😄 ) The next step for this kit is a quick bath in the ultrasonic cleaner and then some metal prep and initial primer. For the final colour, I first need to do some colour matching ... Finally, quick comparison of the blasted EF13 and the shell of the H0 EF66. The blasting does definitely make a difference, and pretty sure it will make the metal prep / primer stick much better. 4 Link to comment
Madsing Posted March 16 Share Posted March 16 Interesting. I didn’t know sandblasting was used for brass kits. Could you post a link to the equipment and materials you have used? Not that I plan to try any time soon, but I’d be happy to know. Marc Link to comment
Martijn Meerts Posted March 17 Author Share Posted March 17 10 hours ago, Madsing said: Interesting. I didn’t know sandblasting was used for brass kits. Could you post a link to the equipment and materials you have used? Not that I plan to try any time soon, but I’d be happy to know. Marc I don't know if sand blasting brass is a common thing, it's just something I wanted to try. My main problem with brass has been getting paint to stick to it. My first attempt at priming brass, I could scrape off the primer just with my fingernails, even with Tamiya metal prep applied. I stripped it all off, then applied a coat of VMS metal prep (this stuff definitely helps, and it designed for preparing photo etched parts), but it's still not great for rolling stock that you might have to handle regularly. Roughing up the service with a fiber brush or sand paper is of course also doable, but it's often hard to reach all the small corners, and the small cast brass detail bits are challenging to sand. For the equipment, I have a Paasche ER-1S. It comes with a small bottle of blasting medium, but like I said, that stuff is toxic. After reading some comments from people who used this sandblaster, they recommended going with either baking soda or glass beads. Baking soda is silly expensive here, so I went and looked for some glass beads. Managed to find a company that sells them in large quantities and in various sizes (I can't remember the homepage, but it's a Dutch shop, so not sure how relevant that would be anyway 🙂 ) Still have to check if it does make a difference for getting the paint to stick of course, but I'll hopefully get to that sometime soon-ish. I did get some new metal prep, since my old one had expired. I also got some VMS primer to test that as well, it's a relatively new product from them, but all of the stuff I have from them so far has been great. I'll probably do some tests on some bits of scrap brass sometime in the coming days. 1 1 Link to comment
Martijn Meerts Posted March 31 Author Share Posted March 31 Again, not much progress.. However, I did have a visitor last weekend, so that was a good opportunity to clean up the train room a little bit and actually connect up what I've built so far. The somehow ever returning mess on the attic really doesn't do much for one's motivation. But now that I can actually see the floor again, and walk around without having to step over things, some of the motivation is coming back. I was able to run a couple of trains (or, locomotives at least) through the yard and helix. I had also wired up most of the shinkansen and express tracks. Those are all getting power, apart from the 1 track that's not supposed to get power yet. In the coming days/weeks, I will temporarily move my resin 3D printer off to the side somewhere, so I have more space for the filament printer and the paint booth. The idea is to finally try and paint some of the brass kits that are mostly done. That would be the N scale EF13, the H0 1067 Hokutan #2 steamer's shell, the H0 1067 Kiwa 90 as well as the H0 1067 C11. Other than that, I've also ordered 2 new build plates for the Bambu Lab A1. 1 is a completely flat one rather than the textured one that came with the printer. And another is one made specifically for PLA and PETG and should have more tackiness, which should make large prints less prone to warping around the edges. The reason for this is that I want to finally print some small cabinets and drawers for storing small items. I also want to experiment a little more with printing some buildings, even if they're just placeholders. Should help out with city planning end the like 🙂 I also came across a bunch of card stock I had ordered quite a while ago, so I dusted off my Inkscape installation to design some interiors for cardstock kits, and then use the Cricut to cut them out. Finally, I decided to order a plunge cut router, so after I've gotten a bit more comfortable using that, I'll continue the woodworking for the next segment of the layout. Link to comment
Martijn Meerts Posted April 9 Author Share Posted April 9 Well, the router delivery seems to have been delayed by quite a bit, not sure why, but apparently the store is having some issues getting the thing delivered from their supplier. I did receive 2 of the 3 router bits I ordered along with the router, and while they look good, they're also rather useless at the moment 😄 I did end up working on a couple of different things. I printed the track plan for the next segment of the layout on 1:1 scale a while ago, so I decided to stitch them together. As is usually the case, seeing this on actual full scale gives it an entirely different look. The tracks on the left here are the shinkansen and express lines, the ones to the right is the urban line. The shinkansen and express lines are simple enough, and those can go in as is. The urban line I'm not too sure about seeing it like this. It looked better in the track plan posted here: https://jnsforum.com/community/topic/15623-jr-chiisai/page/4/#comment-262133. I think it might be a bit too crowded with track around the locomotive service area. I will probably temporarily lay down some track and place some buildings / building placeholders to get a better idea of things, but I'll likely need to make some changes. Speaking of buildings ... I made a quick test project to cut on the Cricut. These bits are a copy of the main interior support walls of a TDF building. Obviously I'm not planning on re-creating buildings that are available from manufacturers, I just want something I can compare. This is also a good base for the correct measurements of windows and doors, so I can start drawing up custom buildings. Initially I tried drawing these up in Autodesk Fusion, so I could use the sketch itself to export to the Cricut software, and then use the actual 3D version to 3D print it. However, Fusion and Cricut apparently don't like each other all that much 🙂 5 Link to comment
Martijn Meerts Posted April 22 Author Share Posted April 22 Got a little more work done on the layout. I'm still trying to go up to the attic every day, even if it's just to run a train on my speed measurement loop. Due to various life things, motivation is pretty low at the moment. The router finally arrived (minus 1 router bit that got lost during transport), so I removed the side wall of the first section of the layout to use that as a template for the second section. I had to improvise a bit since I don't have a decent workbench yet, so holding the plywood in place wasn't easy. That in turn made it a bit more difficult to use the router, but got it done in the end. Top one is the original, bottom one is the newly cut version. The various corners needed a little extra attention since the router bit can't get there. Considering this was my first time using a router though, I'm fairly happy with the result. Both sidewalls in place, they line up really well. Next step is to cut the various cross sections to shape, and then work on cutting and installing the roadbed. I had drawn up how to cut the cross sections, but then I noticed that in my Anyrail design, I only had 2 cross sections instead of the 3 I actually installed in the frame. So I have to go back to the drawing board and measure everything again for the cross sections. The track plan has also been updated a little bit. The bright green bits in this screenshot are where the legs are attached to the frame. I hadn't taken these into consideration when drawing up the original service yard. So I had to move some track around. I also moved the curves for the urban and local lines outwards a bit, to give the service yard and turntable a little more room. The service yard will likely still see some more changes once I start experimenting with it with actual track. Finally, my new collection of tools is starting to grow. Still a few things left to pick up, but one tool at a time. I'm still rather amazed at how well the dust extraction works. I used both the jigsaw and router quite a bit on the attic where the trains are, and there wasn't a spec of sawdust on the layout at all. There was only a little on the floor right below where I was using the tools. 6 Link to comment
Martijn Meerts Posted May 6 Author Share Posted May 6 Due to a very serious health issue in the family, progress hasn't been great. Only in the recent couple of days have I been able to pick up some of the bigger tasks again .. Some small ones first though, built this little Tokyo Diorama Factory coffee stand. It's a little bit wonky here and there, but fixable. The quality is really good, but not quite Sankei good. I also received a sample package of some ballast. I tried the Koemo ballast earlier, which did look good, but discoloured quite heavily when glued down. This new ballast is from Schotterkunst. The ballast in the picture is a pre-made mix which they describe is for "relatively new track where the ballast has been renewed 2 or 3 times". They have 14 other mixes ranging from grey ballast for newly laid track, to almost black ballast for steam service terminals. Once glued, there is only a minor discolouration. In this picture half is glued while the other half isn't. I still need to experiment a little bit more with the colours to determine which I want to use. I have samples in both N and H0. The last few days I finally managed to get some more woodworking done. Cut all the cross sections as well as the sub roadbed. I messed up the measurements a bit for the cross sections, but that's easily fixable. I just need to cut the end piece now, and then the 2nd segment's frame will be done. Glued on some cork for the urban line / service terminal, and the express line. I also have the missing parts (right side of the picture) of the sub roadbed already mostly cut. I just need to cut them to length, but I need the end plate for that first. That's probably something for the weekend. In the meantime, I'll glue the cork to the shinkansen line, sand it all smooth, and then give the cork a bit of an earthy colour. After that I can continue laying track. 8 Link to comment
Martijn Meerts Posted May 12 Author Share Posted May 12 Health issues are still ongoing, but I've found that working on the layout is taking my mind off things a bit. I worked on it quite a bit over the past weekend. Finished gluing up the cork and sanded it. The urban (front) and express (middle) lines are still a bit too long. I'll cut those to length when I've finished cutting out the right edge of the section. Painted the cork a dark earth colour. I've used Woodland Scenics earth undercoat with a little black mixed in to paint them. Adjusted the track plan a bit again. I was looking at making it possible to get a locomotive from the 3 through tracks to the depot without shunting too much on the main line. Initially I tried using some double slip switches, but that looked off, and after getting some advice about it not being accurate for JNR, I redid it again to get to this design. It's still not very JNR due to having quite a few turnouts, but I also want a certain amount of play value. Considering the main line trains will be computer controlled, it made sense to get most shunting off the main line. In this plan: The orange line is the main line for the urban trains, the lighter orange in the station are where trains will stop. The middle track is a passing track for rapid urban trains, and also for freight to park to make space for passenger trains to pass The top cyan track is the local line platform (shown in blue for the rest of the plan). The bottom cyan track is for getting access to the service yard, and possible also for some special trains. The blue line is the local / mountain line. The short blue section in between the turnouts can be used for temporarily storing trains / locomotives The dark violet tracks going into the service shed are diesel / electric service tracks The yellow track is a MoW storage track The red track is additional access to the turntable For the bottom 5 parallel tracks, the top one is for picking up ash from the ash pit. The pit will be located somewhere in the top one of the 3 parallel tracks going into the turntable. I might extend the pit to the top 2 tracks The black track at the bottom is for coal delivery. Coal will be delivered via short trains on the local line. The bright green blocks are the table legs, I'll try to build a coal bunker / coaling tower around that area. Coaling tower will probably be able to service the bottom 2 of the parallel tracks heading into the turntable The turntable position / size / connected tracks are just in indication. I'll be use a World Kougei turntable, so I'll need to see what's possible once it's built. The track plan looked rather busy, so I decided to try it with actual track. I had a bunch of turnouts available since I ordered quite a few of them a while ago to build this segment. With the changes I need some additional turnouts, but I did manage to get quite a bit of it in place. Track is screwed down, but not wired yet, since I'm not 100% certain this is the final track plan. Closeup of the station area, this will definitely stay as it is. Tracks along the platform are a little over 1 meter in length, so plenty space for some urban trains. Closeup of the station approach. It still looks quite crowded, but looks less crowded than it did in the track plan. I'll do a bit of playing around with some cars/coaches to see if this works like I want it to work. Overall I'm quite happy with it, and I think once there's ballast and buildings, all the turnouts won't be as noticeable as they are now. 4 Link to comment
Martijn Meerts Posted May 12 Author Share Posted May 12 Quickly tried a few trains for some length testing. Looks about what I was expecting. The urban platforms are maybe a bit long, they can hold around 7-8 coaches. Local line can hold 3 car trains / loco + 2 cars, and if I do decide to add a platform to the shortest track, that could hold 2 car trains. Might be a good place for the fox / squid / crab Kihas. Will do more experimenting once all the track is lined up between the 2 sections and the sub roadbed is screwed in place. Need to fine tune the position a little bit. 3 Link to comment
Martijn Meerts Posted 7 hours ago Author Share Posted 7 hours ago Took another picture of some test trains in a possible position they could be in during running. It's all a bit tight, but going from some pictures and videos I've since watched, the clearance between the trains isn't unrealistic. I still need to test with some additional coaches. Meanwhile, I've also temporarily put down the track for the shinkansen line, and started working on the express line. I've also measured everything up, and sketched out everything for the segment end, Haven't gotten around to actually cutting it yet, but that's basically the next step. I'll try to do that next weekend. The next segment will be the last one on this side of the layout, so the cross sections there will be a bit more complex with all the curved tracks. I have started looking into it, but I first need to finalise the track plan for that corner, which I can really only do once the segment I'm working on now is (mostly) done. I've noticed that the track plan isn't 100% the same as the actual track, the urban line for example gets a bit closer to the express track than I thought it would based on the Anyrail track plan. That's not really an issue, but definitely something to keep in mind. I also need to determine the depth of the next segment after the corner segment, since that partially also determines the track plan. I will probably try to set up some temporary things with some spare plywood / foam / timber to see what works and what doesn't. Link to comment
