Gerry Posted March 9, 2019 Share Posted March 9, 2019 Hi folks, I am new to this forum and would like to ask a question. I have acquired a Tomix N-DU202- cl controller which is doing everything right, except that the maximum voltage at the feeders does not exceed 6.2 Volts maximum. A bit too little for my (small) HO scale locos. I thought that feeder output should be 12 volts, so is there anything wrong with it or is there a way to adjust the voltage? Thanks for any reply, Gerry Link to comment
Sheffie Posted March 9, 2019 Share Posted March 9, 2019 The obvious question is, what is the voltage across the output terminals of the controller? If it’s normal, then you have a wiring problem. If not, the controller has an issue. Link to comment
bill937ca Posted March 9, 2019 Share Posted March 9, 2019 (edited) That is a controller that controls two trains. Generally Tomix controllers do not exceed 12 volts or sometimes achieve 12 volts. (The Tomix N-400 controller is a 9 volt tram controller). I wonder if the 12 volts is split between the two tracks. Here is a bit of information in English which says each track should be 12 volts DC. http://www.newhallstation.com/estore/product_info.php?products_id=1039 Edited March 9, 2019 by bill937ca Link to comment
Martijn Meerts Posted March 9, 2019 Share Posted March 9, 2019 Check your input as well, if you're powering it with an adapter that has less than 12V,the output will never reach 12V either. I have the same issue with a simple Kato controller that came with a 10-ish volt power supply, so the output is around 9V give or take. 1 Link to comment
cteno4 Posted March 10, 2019 Share Posted March 10, 2019 I think a multimeter May read an average voltage if it used pwm output. jeff Link to comment
Gerry Posted March 11, 2019 Author Share Posted March 11, 2019 Thank you, friends. I shall have a go on it next weekend, following your advices, and report on how it went. Gerry Link to comment
