chadbag Posted March 16, 2019 Author Share Posted March 16, 2019 13 hours ago, cteno4 said: Yes, I was just thinking on this as you responded! You are spot on the circuit looks to work and the perception of flicker can then be tested with number of leds and capacitance I the circuit! might hook it to 12v and leave it on for a few days to torture test. OK, my previous test was manually touching it to my DCC programming track (and pushing the DCC track signal through it). Taking this suggestion, I soldered some wires to the rectifier bridge and hooked up a barrel jack female adapter and plugged in one of my variable voltage power supply bricks (some $9-12 on Banggood -- 9-24V). I am leaving it on. This is with 300 uF in caps and 2K in resistors. Turning off the power it does last a good time -- should be enough to easily mitigate short loss of power that causes flicker. This is a 5V regulator so the LEDs are running in a 5V system. The current across an LED seems to be about 2.3-2.5ma if I did it right (put it on the 20m setting on the Ammeter side). I assume an SMD LED will be in the same ballpark. So even with up to 14 LEDs we'll have 35 or 40 ma so even lightweight simple voltage regulators should work fine. Link to comment
chadbag Posted March 16, 2019 Author Share Posted March 16, 2019 (edited) So I ordered 100 boards. We'll try these (whoever wants some they are 57 cents each plus shipping). I shipped them DHL which was about $7 more than registered mail (but 2-4 days instead of 2 weeks or more) which is why they are slightly more than the 40-50 cents I had mentioned earlier. If these work, 3000 of them come to about 21 cents each delivered to the US (UPS delivery, which is only a day or so slower than DHL). If we like these I'll put the Gerber files up somewhere so that anyone can have their own made if they don't want to go in on group purchases. (1000 is only about 24 cents each so we don't need that many takers to make them really cheap -- the 3000 price is not much less per unit than the 1000 -- just FYI -- 10000 is about 19 cents a piece, so once you get into the 1000s of units, the price does not change that much -- some of the costs are fixed and some are based on quantity so the fixed costs really becoming nothing per board when you get to the 1000s, but the 10s or a 100 it is more significant. Since most trains are 4-10 cars, I'll be wanting several hundred of them myself (it may take me a million years to get them all made). I suspect a few others here will want some. I got these ones in blue since the board color did not change the price. Edited March 16, 2019 by chadbag Link to comment
Martijn Meerts Posted March 16, 2019 Share Posted March 16, 2019 I'd definitely be interested in trying some. Optimally I'd like the various components with it as well, they're often a pain to find in the Netherlands. There's an online shop that has a LOT of components, but their descriptions are pretty poor, so it's rather easy to order the wrong components, and they can be quite expensive unless you order huge numbers. Link to comment
gavino200 Posted March 16, 2019 Share Posted March 16, 2019 Regarding the question about running multiple LEDs in parallel with a single resistor. I've used the product below for a few years with a single resistor using bot 12V and 5V DC power supplies. No problems. No blown LEDs. Come to think of it I don't thing I've ever had a single case of LED failure over time. Just sayin'. https://www.aliexpress.com/item/DD85W0850-1-Strip-50-LED-Pre-soldered-micro-Copper-Wired-WHITE-SMD-LED-0805/32801413908.html?spm=a2g0s.9042311.0.0.27424c4dahFYNZ Link to comment
gavino200 Posted March 16, 2019 Share Posted March 16, 2019 55 minutes ago, chadbag said: So I ordered 100 boards. We'll try these (whoever wants some they are 57 cents each plus shipping). I'll take as many of those as you want to spare. If they work well, I'm in for a lifetime supply. Link to comment
chadbag Posted March 16, 2019 Author Share Posted March 16, 2019 15 minutes ago, Martijn Meerts said: I'd definitely be interested in trying some. Optimally I'd like the various components with it as well, they're often a pain to find in the Netherlands. There's an online shop that has a LOT of components, but their descriptions are pretty poor, so it's rather easy to order the wrong components, and they can be quite expensive unless you order huge numbers. I ordered a large number of LEDs, resistors, and caps and voltage regulators. I'd be happy to throw a set together with the board for you (in whatever quantity) once we arrive at optimal values for each. I think, based on some experimentation already, I know what those are or close to what they may be, but we need to make sure. The LEDs, caps, and voltage regulatros and rectifiers don't really change so those are the things I ordered in large numbers already. Link to comment
chadbag Posted March 16, 2019 Author Share Posted March 16, 2019 9 minutes ago, gavino200 said: I'll take as many of those as you want to spare. If they work well, I'm in for a lifetime supply. Of the first 100, depending on how many other people want some, you can have a bunch. But once it has been tested in real life and we think it works great, we'll get a larger order in to reduce the cost per board and you can have as many as you want. For the 20-50 US cents they cost (closer to 20 at larger qty), you can stock up for not a lot of money. Link to comment
chadbag Posted March 16, 2019 Author Share Posted March 16, 2019 I first placed the order for the 100 last night, but they audited it and rejected it. I had not created the gerber files correctly and was missing the drill files. They refunded the payment. I re-built the gerber files, being more careful this time, and re-ordered. This one passed the audit and is "in production". They should ship sometime this week and be here DHL fast so hopefully in a week I can start some tests and if they work send them out to folks who want them. I am also going to re-layout the board to make a new version that has the LEDs in a straight line. Same circuit everything, just laid out a bit differently to try and make it thinner. Also, I was looking at it and if you are hooking up a DCC decoder to the board (and it has a blue common or you are fine with the half wave rectification of using a track wire as a neg), you can leave the rectifier off, and solder the decoder track wires to where the track wires are attached to the board, use the 2.54mm pins to hook up the track wire, and put the decoder where the rectifier is, more or less (if it is small enough). We'll see how it works. The nice thing is you can always use the DCC decoder with the rectifier on the board so you can use it either way without change. Link to comment
Martijn Meerts Posted March 16, 2019 Share Posted March 16, 2019 38 minutes ago, chadbag said: I ordered a large number of LEDs, resistors, and caps and voltage regulators. I'd be happy to throw a set together with the board for you (in whatever quantity) once we arrive at optimal values for each. I think, based on some experimentation already, I know what those are or close to what they may be, but we need to make sure. The LEDs, caps, and voltage regulatros and rectifiers don't really change so those are the things I ordered in large numbers already. Sounds great. I need to find some suitable coaches to install them in, and I can try various manufacturers and from various time periods. My oldest coaches are probably older than I am. Link to comment
cteno4 Posted March 17, 2019 Share Posted March 17, 2019 Moved the power pickup and power coupler discussion into its own thread as picking up some steam there. jeff Link to comment
chadbag Posted March 18, 2019 Author Share Posted March 18, 2019 On 3/16/2019 at 1:23 AM, cteno4 said: might hook it to 12v and leave it on for a few days to torture test. I've hooked it to 12-15V (I vary it as the power supply is variable) and leave it on whenever I am in the area (and it is in my day job home office so is on most of the time during the day / evening). No problem being left on, and feeling the rectifier chip and voltage regulator chip, no warmth at all with the current 2 LEDs pull. I suspect 14 LEDs won't show any heat at all as well. Link to comment
cteno4 Posted March 18, 2019 Share Posted March 18, 2019 Cool. Always good to check! It will be interesting to see how much current is needed as you increase the number of leds. Theoretically you are just spreading the light out over more area, but I suspect it will need a bit more overall current, but always hard to tell until you try it to see how it will look to the eye. Light does not scale literally and thus it’s effect in models is something to just keep trying and playing with until you get the right result. I learned this big time way back when I worked with a couple of high end model/product shooters. Lighting was the total art for them and when I tried to get rules from them to work from there were not many, more of a process to quickly try things to start zooming in on what looked the best for each setup! Sometimes we would just move the camera a foot and a small angle change on the huge 3/4” scale model and the lighting would get totally redone a different way. But the results were always amazing and each shot thru the model felt like they were in the same place but required different things to get there! it looks like the main dropping resistor has big enough pads to pop on a 3x3mm smd pot to play easily if desired. cheers, jeff Link to comment
chadbag Posted March 18, 2019 Author Share Posted March 18, 2019 7 minutes ago, cteno4 said: it looks like the main dropping resistor has big enough pads to pop on a 3x3mm smd pot to play easily if desired. I have some (not SMD but breadboard) variable resistance pots coming if they ever get here (ordered Feb 4 -- last track like 2 weeks ago). For testing. Link to comment
cteno4 Posted March 18, 2019 Share Posted March 18, 2019 The little 3x3 smd are nice. You can’t reset them hundreds of times but are good for a couple of dozen tweaking. Usually once set that’s good. the 7x7 pinned guys are a bit heartier for more playing. jeff Link to comment
chadbag Posted March 18, 2019 Author Share Posted March 18, 2019 16 minutes ago, cteno4 said: The little 3x3 smd are nice. You can’t reset them hundreds of times but are good for a couple of dozen tweaking. Usually once set that’s good. I ordered a set pf 20 2k ones to try out. I am trying to find something similar that is basically a 2 position switch that will choose between two paths. Ie, 2 inputs and two outputs, and the switch will choose between the left and right paths. (ie left in and out are connnected and right in and out are connected). If such a thing exists, my Ali Express and eBay search-foo is failing. In the straight-LED version of the PCB, I'd like to add in a switch that allows two different dimming resistors to be used (like some of the commercial light boards). But need a versy small switch. I have some push button ordered but would like to try some small rotary Link to comment
cteno4 Posted March 19, 2019 Share Posted March 19, 2019 You want a DPDT switch. Double Pole Double throw. Means there are two poles you can throw to two different end positions SPDT is single pole that can be thrown to two positions SPST. Plain old on off for a single pole. Different styles for DPDT toggle on/on https://www.aliexpress.com/item/5PCS-Lot-High-Quality-6Pin-DPDT-ON-ON-Mini-Toggle-Switch-6A-125VAC-Mini-Switches/32810283048.html?spm=2114.search0104.3.204.9eff605d7A4vZC&ws_ab_test=searchweb0_0,searchweb201602_5_10065_10130_10068_10890_10547_319_10546_317_10548_10545_10696_453_10084_454_10083_10618_10307_537_536_10902_10059_10884_10887_321_322_10103,searchweb201603_70,ppcSwitch_0&algo_expid=d25b1185-a2a8-482f-b053-aec75b7b4386-29&algo_pvid=d25b1185-a2a8-482f-b053-aec75b7b4386&transAbTest=ae803_4 Toggle center off on-off-on https://www.aliexpress.com/item/Promotion-5pcs-3-Position-2P2T-DPDT-ON-OFF-ON-Miniature-Mini-Toggle-Switch-6A-125V/32815651213.html?spm=2114.search0104.3.116.8a04172atdcxrj&ws_ab_test=searchweb0_0,searchweb201602_5_10065_10130_10068_10890_10547_319_10546_317_10548_10545_10696_453_10084_454_10083_10618_10307_537_536_10902_10059_10884_10887_321_322_10103,searchweb201603_70,ppcSwitch_0&algo_expid=832aa650-ee26-464b-ae2c-5a8770d8dfce-16&algo_pvid=832aa650-ee26-464b-ae2c-5a8770d8dfce&transAbTest=ae803_4 Little slide ones for pcb on/on https://www.aliexpress.com/item/20PCS-SS22D07-SS-22D07-6PIN-2P2T-DPDT-toggle-switch-side-slide-switches-handle-4mm-ROHS/32795075542.html?spm=2114.search0104.3.114.9eff605d7A4vZC&ws_ab_test=searchweb0_0,searchweb201602_5_10065_10130_10068_10890_10547_319_10546_317_10548_10545_10696_453_10084_454_10083_10618_10307_537_536_10902_10059_10884_10887_321_322_10103,searchweb201603_70,ppcSwitch_0&algo_expid=d25b1185-a2a8-482f-b053-aec75b7b4386-16&algo_pvid=d25b1185-a2a8-482f-b053-aec75b7b4386&transAbTest=ae803_4 For push button you need to specify latching so it clicks into each posisiton or its usually only momentary contact while pushed. On/on https://www.aliexpress.com/item/30pcs-lot-Square-7x7x12mm-6-Pin-DPDT-Mini-Push-Button-Self-locking-Switch-G64-Multimeter-Switch/32874883200.html?spm=2114.search0104.3.44.9eff605d7A4vZC&ws_ab_test=searchweb0_0,searchweb201602_5_10065_10130_10068_10890_10547_319_10546_317_10548_10545_10696_453_10084_454_10083_10618_10307_537_536_10902_10059_10884_10887_321_322_10103,searchweb201603_70,ppcSwitch_0&algo_expid=d25b1185-a2a8-482f-b053-aec75b7b4386-6&algo_pvid=d25b1185-a2a8-482f-b053-aec75b7b4386&transAbTest=ae803_4 Cheers jeff Link to comment
chadbag Posted March 19, 2019 Author Share Posted March 19, 2019 (edited) Thanks! https://learn.sparkfun.com/tutorials/switch-basics/all For my purpose, I really want SPDT as I want to route a single input to one of two outputs (resistors) Edited March 19, 2019 by chadbag Link to comment
cteno4 Posted March 19, 2019 Share Posted March 19, 2019 Sorry I spaced your last comment there on using on the board. Getting really tiny for a dpdt is tough. Couldn’t you use a SPDT as it should be just one pole between 2 paths thru two different resistors https://www.ebay.com/itm/20pcs-Mini-Slide-Switch-On-OFF-2Position-Micro-Slide-Toggle-Switch-SMDCSY/372577745717?hash=item56bf5d3b35:g:3wEAAOSw8SpbCMfk dpdts get big https://www.ebay.com/itm/20Pcs-2-Position-Vertical-Angle-6P-DPDT-Micro-Slide-Switch-Latching-Power-Switch/232214845944?epid=515225807&hash=item36111559f8:g:XNEAAOSwKbpbmwCK jeff Link to comment
cteno4 Posted March 19, 2019 Share Posted March 19, 2019 Our posts passed in the night jeff Link to comment
chadbag Posted March 19, 2019 Author Share Posted March 19, 2019 This looks to fit the bill (small etc) https://www.aliexpress.com/item/50-PCS-DC-50V-7-Pin-On-On-2-Position-1P2T-SPDT-SMD-Slide-Switch-Side/32620716121.html Link to comment
cteno4 Posted March 19, 2019 Share Posted March 19, 2019 Yep same ones I linked to on ebay. I think you can get them even cheaper on aliexpress. jeff Link to comment
chadbag Posted March 19, 2019 Author Share Posted March 19, 2019 Actually they do look the same now that I look. I had looked at the eBay ones but they did not show dimensions and I did not connect the two listing until you mentioned it. Thanks! Link to comment
chadbag Posted March 20, 2019 Author Share Posted March 20, 2019 The boards are about 40% through production. I have already identified a major change to make to the circuit to incorporate into the V2 board (non staggered LEDs [but that is not the change]). I was looking at other designs online for similar circuits (usually much simpler and for H0) and a bulb went off on why I see what I see with the current test wiring I have. I'll post the circuit tonight or tomorrow once I have it designed in the circuit designer. (Not the PCB designer). Link to comment
gavino200 Posted March 20, 2019 Share Posted March 20, 2019 (edited) On 3/18/2019 at 6:06 PM, chadbag said: I am trying to find something similar that is basically a 2 position switch that will choose between two paths. Ie, 2 inputs and two outputs, and the switch will choose between the left and right paths. (ie left in and out are connnected and right in and out are connected). If such a thing exists, my Ali Express and eBay search-foo is failing. Why do you want to do that? I believe the Popondetta LED sticks incorporate a switch so that they can be used for either DC constant lighting circuits or DCC. TORMs don't have this. They look good with DC but shine like little suns on DCC. But in our situation we're going to chose the resistor ourselves. We can choose specifically what looks best for a particular train. There should be no need to change it. It's not practical to switch resistance for day/night or some other changing ambient condition. You'd have to open all the cars to make the switch. That may ruin the flow of your play session. I think it would be better to leave out this feature. How are you designing the circuit. Will it be possible to just ignore this and not solder in a switch? Edited March 20, 2019 by gavino200 Link to comment
chadbag Posted March 20, 2019 Author Share Posted March 20, 2019 40 minutes ago, gavino200 said: I think it would be better to leave out this feature. How are you designing the circuit. Will it be possible to just ignore this and not solder in a switch? Yes, the default is to not put the switch in. In fact, to use the switch, you'll need to cut a trace before you put the switch on the board. 1 Link to comment
