EdF Posted December 3, 2018 Share Posted December 3, 2018 Any ideas if I could de-motor a second E259 set and run the 12 cars on 1? They look to plan to do this with the E353, and it would save me buying another EM13 and needing to speed match (since I speed match my trains to proto top speeds). Link to comment
katoftw Posted December 3, 2018 Share Posted December 3, 2018 Yeah just disassemble the motor chassis and bogies. Then rebuild without the motor, driveshafts and gears. The axles will have gears, but without any other gears to play against inside the bogie, then they will spin freely. 1 Link to comment
Welshbloke Posted December 4, 2018 Share Posted December 4, 2018 Remember to put the bits you remove aside somewhere. If the other motor should eventually wear out you have a spare then. 2 Link to comment
