Using real coal for car loads
shadowtiger25
shadowtiger25
A guide no one asked for!
To start, you will need
A lump of coal
Ether plastic inserts, or foam inserts that you make yourself to the measurements of your car
A moral and pastel or a hammer and a metal bowl you dont care to beat the crap out of
White glue
50% isopropyl alcohol
Some cotton swabs
Some containers for small amount of liquid
A bottle cap
An herb grinder, or something else to grind the larger bits in to smaller
Some vaper-wave to chill to as you work personally I recommend
or
shadowtiger25
First off, a of the base plastic and the coal added loads
Step 1:
Mix your white glue with 1 part glue to 1 part water
Using a cotton swab, wet the the plastic with glue. I go one side then the other so I can hold the load
shadowtiger25
Step 2
Take a bottle cap and scoop the grade of coal you want to have in your load, making sure to have coal dust in the mix.
Sprinkle over the glue.
Repeat step 1 on the small side that was not glued
Notice how I have multiple grades of coal in my bin? The larger is for my locos, and the smaller is for loads. I will talk about the coal grades at the end.
And sorry about shaky camera in last photo...
Edited by shadowtiger25
shadowtiger25
Step 3
Wet the coal with the 50% isopropyl alcohol (this allows the glue to soak into the coal, and makes it stick better.
Then add more 50/50 glue mix on top of the coal.
Sprinkle with mostly coal dust. This second layer helps hide the plastic and improves the look. you do not need to do any more layers.
wouldn't let me add pics
shadowtiger25
Step 5
Once dry, you will most likely will need to shave some glue off the edge of the plastic to make it fit. I like to make it so the loads slide out easy so I can run empty's and pack up with out damaging loads
You can do this by taking a flat xtaco blade and scraping it off
And the finished look in the car
shadowtiger25
Ok, now for grades of coal.
there are 6 grades, or sizes of coal.
Stove, Chestnut, Pea, Buckweat, Rice, and Barley.
http://photobucket.com/gallery/user/battyice/media/cGF0aDpDb2FsIFJlbGF0ZWQvQ29hbF9TaXplcy5qcGc=/?ref=
Examples in cars
https://www.wvencyclopedia.org/assets/0000/8061/N_W_Railway_up_large.jpg?1276869651
http://www.mccomaswv.com/images/lamartipple.jpg
A good resource talking about it
http://2railoscale.blogspot.com/2015/02/thoughts-on-modeling-coal-operations.html
I dont know what grade JNR transported, but it looks like the smaller in videos
Edited by cteno4
Image uploads
shadowtiger25
I want to point out something. This guide is for HO, however, it can be used for N-scale to. just scrape coal off from the lump. A comparison of the scale size I made. HO on left, N on right.
Last note, my SL load, next to the coal cars
