martyn54lg Posted June 1, 2018 Share Posted June 1, 2018 Hi, I'm new to this forum (live in the UK). I use Tomix wide tram track on a town layout I'm building and have just invested in a pair of Tomix controllers & two TCS units to automate the double track tram looped circuits to include a couple of tram stops on each circuit. I also have 4 of the short sensor track pieces. However, the instructions are all in Japanese and I'm having a devil of a job sorting out how to do the wiring to achieve this. Anyone got any tips or links that might help me? Link to comment
cteno4 Posted June 1, 2018 Share Posted June 1, 2018 marty, have you tried the google phone app for translating? it works well for small bits like instructions like this and can help give you a start. there are a few folks on the forum who have the tomix tcs system and hopefully someone can help with questions. cheers jeff Link to comment
kvp Posted June 1, 2018 Share Posted June 1, 2018 http://www.tomytec.co.jp/tomix/world/autounitn/unit5563.htm Two loops, two units, four sensors, no turnouts. That's probably program 6 with the two stop sensors chained together (times two, one setup for each loop). The sensors go towards the middle of the stops for short trams. Connect one directly to the TCS unit and the other to the first sensor. The tram will loop around and stop at each stop. The maximal number of stops is not really limited but only one tram can run on a single loop. The classic automation unit can only move one train at a time. Link to comment
martyn54lg Posted July 6, 2018 Author Share Posted July 6, 2018 Thanks for all your help and advice guys. Sorry I haven't responded sooner, have been away. Now I'm back I'll try your suggestions. Link to comment
AllScales Posted July 31, 2018 Share Posted July 31, 2018 I’ve got two of those pieces on order and will analyse how they work... Somewhat related: To control Tomix points without a Tomix power unit, should I get a 5500 and 5531’s & 5532’s for the points? I assume the 5500 is fed with 12V DC? Link to comment
AllScales Posted July 31, 2018 Share Posted July 31, 2018 And a 5533 looks like a section isolation switch/reverse loop switch? Link to comment
brill27mcb Posted July 31, 2018 Share Posted July 31, 2018 4 hours ago, AllScales said: I’ve got two of those pieces on order and will analyse how they work... Somewhat related: To control Tomix points without a Tomix power unit, should I get a 5500 and 5531’s & 5532’s for the points? I assume the 5500 is fed with 12V DC? Your answer is here: http://www.trainweb.org/tomix/control/tomix_control_systems.htm Rich K. Link to comment
katoftw Posted July 31, 2018 Share Posted July 31, 2018 It doesnt say in the link. But the two power feeds for the 5500 are kato plug and the other just stripped wire for clips? Link to comment
kvp Posted August 1, 2018 Share Posted August 1, 2018 The Tomix 5500 is an AC 16-24V to DC 12V converter. So it should be fed with around 16V to 24V AC or DC. The minimal voltage loss in the unit (if it uses a 7812 and a diode bridge) should be around 3.4V at least, so the 16V minimal input is a good idea to get a stable 12V output at around 1A. Link to comment
AllScales Posted August 5, 2018 Share Posted August 5, 2018 Right so the Fleischmann 6755 (and it’s A.C. only brother) will be perfect! Link to comment
