Kiran Posted May 24, 2018 Share Posted May 24, 2018 If I have a simple double track in an oval, I am wondering if there is a way to run the feeder cable to the inner loop more efficiently? My plan is to have 2 controllers to run trains in opposite directions. I have to run the power cable under the outer loop to get to the inner. This will raise the track a bit and make the trains derail. I know I can make a small cut in the bottom of the outer loop track but I am wondering if there is a better and cleaner solution than this? I am surprised that they don't make track sections with a little gap at the bottom for running the power cable through. Link to comment
chadbag Posted May 24, 2018 Share Posted May 24, 2018 This is the Tomix FineTrack, right? Link to comment
bill937ca Posted May 24, 2018 Share Posted May 24, 2018 (edited) What kind of Tomix track are you using on the inner loop? Edited May 24, 2018 by bill937ca Link to comment
Kiran Posted May 24, 2018 Author Share Posted May 24, 2018 On 5/24/2018 at 2:05 PM, chadbag said: This is the Tomix FineTrack, right? Expand Correct. Link to comment
bill937ca Posted May 24, 2018 Share Posted May 24, 2018 (edited) Tomix Track Feeders 5534-- basic feeder for under track slot https://www.1999.co.jp/eng/10009865 5537-- DC feeder for Slab track (undersidetrack connection) https://www.1999.co.jp/eng/10047043 5813--DC extension cord https://www.1999.co.jp/eng/10010013 5812--DC branching cord for splitting one DC feeder to two 5534 or 5537 feeders https://www.1999.co.jp/eng/10010012 If you need to run wires under the track there also is the Tomix trough bridge. The prototype is a small girder supporting the track over a stream (which is typically dry most of the time except maybe spring runoffs). This piece uses the height of the roadbed in a different manner than Tomix stock rail. https://www.1999.co.jp/eng/search?typ1_c=104&cat=rail&state=&sold=0&sortid=0&searchkey=trough http://www.tomytec.co.jp/tomix/products/n/3247.html Edited May 24, 2018 by bill937ca Link to comment
bill937ca Posted May 24, 2018 Share Posted May 24, 2018 (edited) On 5/24/2018 at 1:58 PM, Kiran said: I know I can make a small cut in the bottom of the outer loop track but I am wondering if there is a better and cleaner solution than this? I am surprised that they don't make track sections with a little gap at the bottom for running the power cable through. Expand As posted above the solution is a trough bridge, a 70mm section of track. https://www.1999.co.jp/eng/image/10483601/20/2 Its not a power feed so it won't show up if you search for it there. Hobby Search classifies it as Tomix Fine Track but bridges sometimes are classified as structures. Edited May 24, 2018 by bill937ca Link to comment
kvp Posted May 24, 2018 Share Posted May 24, 2018 I would like to add, that Tomix Finetrack is mainly designed for fixed tabletop layouts, this is why most plugs have a small round profile, so they could fit through a drilled hole on the baseboard. The joiners are also more ideal for fixed layouts and not floor running. ps: Tomix tram tracks have slots for routing wires under them and they could also be used as railroad crossing pieces. (one of the pieces already has the slots for the bus system wires too in 4 different crossing angles) Link to comment
katoftw Posted May 24, 2018 Share Posted May 24, 2018 Tomix cables are super flat compared to other makes. I wouldn't worry too much. Link to comment
