oenckie Posted March 8, 2018 Share Posted March 8, 2018 Hi all, Does anybody know if the Marklin k83 switchdecoder can be used with Unitrack switches? I found a couple of those Marklins, and wonder if I can give those something to do :) Thanks in advance! Regards, Marco Link to comment
kvp Posted March 8, 2018 Share Posted March 8, 2018 They are low active switch decoders, so the middle output is power and the two side ones are pulsed to ground. This is only directly usable for the ancient 3 wire Kato turnouts, but you can make a 2 wire adapter circuit. Essentially you just connect 2 dpdt morse relays to each group of 3 outputs and wire the relays to output a polarized 12V pulse when they are activated. (one direction for one relay, the reverse for the other) I'm not sure if it's financially worth it though as all these relays could cost as much as getting a polarity reversal capable decoder. Link to comment
oenckie Posted March 8, 2018 Author Share Posted March 8, 2018 On 3/8/2018 at 9:13 AM, kvp said: They are low active switch decoders, so the middle output is power and the two side ones are pulsed to ground. This is only directly usable for the ancient 3 wire Kato turnouts, but you can make a 2 wire adapter circuit. Essentially you just connect 2 dpdt morse relays to each group of 3 outputs and wire the relays to output a polarized 12V pulse when they are activated. (one direction for one relay, the reverse for the other) I'm not sure if it's financially worth it though as all these relays could cost as much as getting a polarity reversal capable decoder. Expand Thanks! Guess I won't use them then :) Saterday there's a trainevent nearby, I will look for a right decoder. Regards, Marco Link to comment
