The Next Station Is... Posted November 23, 2017 Share Posted November 23, 2017 I came across this idea on Sumida Crossing and it piqued my interest, but I'm having difficulty finding anyone that has tried it and written up their experience. Has anyone here tried hooking up a DCC decoder to a length of track and using it to power a DC locomotive? Sent from my G3121 using Tapatalk Link to comment
katoftw Posted November 23, 2017 Share Posted November 23, 2017 As long as you still pull the power from another source. I cannot see why it wouldn't work theoretically. But you wouldn't have light and/or sound control of the train itself. Link to comment
Kiha66 Posted November 24, 2017 Share Posted November 24, 2017 While you could, you wouldn't achieve anything more than you would with a dc power pack, plus the decoder could burn up with any extra load (lights, ect). What application do you think needs this? Link to comment
inobu Posted November 24, 2017 Share Posted November 24, 2017 9 minutes ago, Kiha66 said: While you could, you wouldn't achieve anything more than you would with a dc power pack, plus the decoder could burn up with any extra load (lights, ect). What application do you think needs this? I had the same idea. It allows you to tie your DC train with your DCC layout. Lets say you have a DC loop and connect the feeders to the Orange and Gray leads on the decoder. If you increase the throttle speed on that address it will act as a transformer. The train on the DC loop will be responding to a DCC throttle command. In order to do this he need to use a G Scale decoder. Typically G-Scale can handle 5 amps which is more than the 1 amp decoder can handle. The only caveat is short circuit protection. Inobu Link to comment
Kiha66 Posted November 24, 2017 Share Posted November 24, 2017 I suppose you could, but since you'd need it to be a seperate segreagated loop of track anyway a dc transformer would be cheaper. Link to comment
kvp Posted November 24, 2017 Share Posted November 24, 2017 It works. Just make sure that the train wouldn't cross into a dcc block and never bridge together two blocks driven by decoders as they are not prepared for their output to be connected to anything else but a single motor. Probably a good idea to turn off backemf control too if the train has lights, otherwise the decoder could get confused. Link to comment
utrainia Posted November 24, 2017 Share Posted November 24, 2017 I've done it, I had a switch before the track that selected straight DCC, or connected the tracks to the output of a spare decoder. That way I could switch between DC and DCC trains for my small railway. Worked well enough, was easier and cheaper than wiring in decoders for every loco.Sent from my Nexus 5 using Tapatalk 1 Link to comment
gavino200 Posted November 25, 2017 Share Posted November 25, 2017 That's a pretty nifty idea. It would allow you to run non-convertible stock with DCC control. Portrams spring to mind. IIRC that's what this system is used for at Sumida Crossing. I wouldn't feel comfortable using it on anything but a designated closed loop though. Otherwise if you forget to trip the switch and run the wrong stock you'll see sparks pretty quick. I think KenS warned about this risk on SC. Unfortunately, I don't have any room on my layout for a designated loop, or even a reversing straight line track. Otherwise I'd install a portram in a heartbeat. Maybe a bus service too. Link to comment
cteno4 Posted November 25, 2017 Share Posted November 25, 2017 I tested this on Ttrak and it worked. The future project will be getting some higher amperage decoders to set up somthat we can run 4 tracks with one remote DCC controller. Shorting the decoder seems to be the issue that may happen. jeff Link to comment
Vato Posted November 25, 2017 Share Posted November 25, 2017 I'm using DCC decoder to control DC locomotives on my temporary layout. works well Link to comment
cteno4 Posted November 25, 2017 Share Posted November 25, 2017 Vato, cool, how big of a layout is it on? What sized decoder are you using? ive actually been tempted to try it on the new club layout whenits running here to see if it could simlify things there with only having a single controller. jeff Link to comment
kvp Posted November 25, 2017 Share Posted November 25, 2017 For short protection, adding a polyfuse to each feeder wire would be enough, but never cross with a train from one loop to another as it could damage the decoders. Btw. using the opendcc variant of decoders could allow us to add proper protection circuits and even to allow syncing up the pwm signals using sideband data. Just like in the new Tomytec system. Link to comment
Vato Posted December 6, 2017 Share Posted December 6, 2017 Vato, cool, how big of a layout is it on? What sized decoder are you using? ive actually been tempted to try it on the new club layout whenits running here to see if it could simlify things there with only having a single controller. jeffIt is a table size simple layout with one double crossover. 120smX60sm. Decoder is from digitrax DZ126.Sent from my Lenovo YT-X703L using Tapatalk Link to comment
