velotrain Posted February 25, 2017 Share Posted February 25, 2017 Since there is a current topic on reducing track noise, I wondered if this is an issue with T-Trak modules, as it seems possible that the box-style construction causes it to act as a sound amplifier? Or, does the open bottom prevent this? If this is the case, how do people reduce the problem - perhaps a thin cork layer under the track? OTOH - since these are more tightly framed than many layout segments, it may not be an issue, as the sides and top are less susceptible to vibration despite their typical thin material. 1 Link to comment
tossedman Posted February 26, 2017 Share Posted February 26, 2017 Ours are pretty quiet. No cork, just Kato Unitrack hot glued to the module. Our modules are small, 308mm X 210mm with a cross member underneath each end so there's not a large area to resonate. Here's the method we used to create our modules. http://ttrak.wikidot.com/1x3s Cheers eh, Todd Link to comment
cteno4 Posted February 26, 2017 Share Posted February 26, 2017 I've never noticed much resonance in Ttrak modules, the boxes are pretty small area as you mention and very stiff with the corner blocks (if you use the usual design). Jeff Link to comment
velotrain Posted February 26, 2017 Author Share Posted February 26, 2017 Thanks, guys - you've put my mind at rest (at least on this matter ;-) Link to comment
cteno4 Posted February 26, 2017 Share Posted February 26, 2017 One thing is we usually don't run large trains or very fast on our Ttrak, but on the big layouts at our Locak shows I've never noticed a lot of sound. Most of the noise on or sectional layout I think come from our Shinkansens, many wheels going fast on a lot of raised viaduct so sound coming out all around. Jeff Link to comment
medusa Posted February 26, 2017 Share Posted February 26, 2017 Most of the noise on or sectional layout I think come from our Shinkansens, many wheels going fast on a lot of raised viaduct so sound coming out all around. Isn't that like in reality? I mean, fast running trains make a lot of noise. Link to comment
gerryo Posted February 26, 2017 Share Posted February 26, 2017 Here in Ottawa, we use 3/4 inch plywood with 2 inch thick Styrofoam on top. Never a sound. Gerry Link to comment
velotrain Posted February 27, 2017 Author Share Posted February 27, 2017 For T-Trak? That sounds like overkill. I know you've done N-Trak in the past - where this would be more appropriate. Ottawa is one of my favorite cities. Link to comment
cteno4 Posted February 27, 2017 Share Posted February 27, 2017 It's an uber simple module approach. 3/4" ply (but you can easily use down to 3/16" ply) base is easy to just bang t nuts into for the legs. The foam to build up and you can easily cut any feature down into the foam. Folks paint the foam edges or put a piece to styrene, thin ply or veneer on the fron face to pretty them up. It's about the same weight as a standard module. For simplicity I love the U modules made from 3/4" shelving. Flip em over for the valley modules. Jeff Link to comment
westfalen Posted February 27, 2017 Share Posted February 27, 2017 Never really noticed any abnormal track noise here either. When our club first changed from Ntrak to T-TRAK we tended to over engineer things a bit too but then we realised one reason we were changing was that modules were easier to construct and set up. I don't think we ever used 3/4 ply even on Ntrak modules. Link to comment
velotrain Posted February 27, 2017 Author Share Posted February 27, 2017 I have always thought that one of the intents of T-Trak was to keep things light, so I couldn't imagine using 3/4" ply, but then perhaps no-one in Ottawa brings their modules to a meet using public transit ;-) Link to comment
cteno4 Posted February 27, 2017 Share Posted February 27, 2017 I'm not sure many folks in North America bring Ttrak to meets via public transit... really tiny bit of weight if you are using public transit as you would be like 1 - 4 modules you would take that way max anyway. It's really about the same weight as an old "standard" construction Ttrak module out of 3/16" or 1/4" when you include those corner blocks. Some make the the standard design out of 10mm ply. The U modules are even heavier as usually out of hardware store 3/4" plank stock, but still not really "heavy". Folks have gone super light and have done all foamcore modules! Jeff Link to comment
westfalen Posted February 27, 2017 Share Posted February 27, 2017 I have always thought that one of the intents of T-Trak was to keep things light, so I couldn't imagine using 3/4" ply, but then perhaps no-one in Ottawa brings their modules to a meet using public transit ;-) We don't either, but we still have to carry them from the car into the hall and it's fun to watch the other exhibitors struggling with their layouts and modules. Link to comment
gerryo Posted February 27, 2017 Share Posted February 27, 2017 It's the 3/4 ply that makes them heavy, of course. And that is why I've made my t-track-z with just 1x2 around the perimeter on the bottom. Gerry Link to comment
