domino Posted July 10, 2009 Share Posted July 10, 2009 Hey Guy`s I just bought catenary set 23-060 and 23-057 for my double viaduct track from the V13 set, but they dont fit . Does anybody know witch catenary that fits ?? Brian domino Link to comment
Bernard Posted July 10, 2009 Share Posted July 10, 2009 Brian - I think you wanted the 23-061 Double Overhead Catenary sets: http://www.1999.co.jp/eng/10058601 I think the V13 track set is a single track and the Viaduct set you have on your layout is double. I believe the ones you bought should work on your other track if you want to use them there. Link to comment
domino Posted July 10, 2009 Author Share Posted July 10, 2009 Brian - I think you wanted the 23-061 Double Overhead Catenary sets: http://www.1999.co.jp/eng/10058601 I think the V13 track set is a single track and the Viaduct set you have on your layout is double. I believe the ones you bought should work on your other track if you want to use them there. hey The V13 is a double track set look : http://www.osbornsmodels.com/kato-v13-20-872-double-track-elevated-set-5790-p.asp But i dont understand , because the 23-060 and 23-057 is for double tracks ,but as you can see on photo they dont fit, i dont understand this? brian Link to comment
Bernard Posted July 10, 2009 Share Posted July 10, 2009 I stand corrected. Take a look at you V13 set, did it come with any catenary poles, or in the manual does it list the part number for the poles you need to use for this set? (I just don't want you to order the wrong part number since I was wrong about the V13 set.) Link to comment
domino Posted July 10, 2009 Author Share Posted July 10, 2009 I stand corrected. Take a look at you V13 set, did it come with any catenary poles, or in the manual does it list the part number for the poles you need to use for this set? (I just don't want you to order the wrong part number since I was wrong about the V13 set.) Your are correct about the 23-061,it says so on the box , dont know why did not see it before Still dont understand why the 23-060 and the 23-057 dont fit, they are for double tracks ?? Brian Link to comment
alpineaustralia Posted July 10, 2009 Share Posted July 10, 2009 The narrower one fits the pier set (eg, the declining peir set) that you can fit to the double viaduct while the other one fits the support peice shown in your photo Link to comment
domino Posted July 10, 2009 Author Share Posted July 10, 2009 The narrower one fits the pier set (eg, the declining peir set) that you can fit to the double viaduct while the other one fits the support peice shown in your photo ahhhhhhhh,ok thanks domino brian Link to comment
