Tomix turnouts in "no-power-routing"
theprez
Hello all, my bad, i should have researched much better before to decide to move to Tomix tracks, I did not realize all the turnouts are all full power routing,
I can not power dead end segments of the layout so without a no-power-routing option i have to mix again with Kato o Fleischmann tracks.
Is there any way to force Tomix turnouts to power all rails? Any wiring diagram around to give it a try?
Thanks in advance
You can open it up and bridge the contacts inside like you would have to do on Kato #6 turnouts or just feed each track behind the turnouts like you would do with Peco tracks. One feed point at the middle of each track should work.
ps: On the other hand, you can wire reverse loops more easily and even cut turnouts without shorts.
