railsquid Posted April 24, 2016 Share Posted April 24, 2016 So, I finally got round to doing unspeakable things with a soldering iron and various bits of electrickery to an ancient Tomix Seibu 5000-kei Red Arrow , namely replacing the olde-style bulb (left) with something more modern (right): In "daylight" the difference is not so apparent on camera, especially in a still shot - when voltage changes the brightness change in the filament bulb is very obvious - but to the naked eye the LED version looks much more "train-like". 2 Link to comment
kvp Posted April 24, 2016 Share Posted April 24, 2016 Nice work! And it seems you choosed a cold white led. Adding a buffer cap is more important here as leds tend flicker more easily on contact loss. Link to comment
railsquid Posted April 25, 2016 Author Share Posted April 25, 2016 Aha, interesting point, thanks. Any recommendation for type/specification, and maybe a simple circuit diagram? I have literally no idea what to look for. Link to comment
kvp Posted April 25, 2016 Share Posted April 25, 2016 Generally you could add a small smd capacitor parallel to your led setup (resistor/led pair). The voltage of the cap should be at least 1.5x of the maximal track voltage on your layout, but i would go 2x, so around 25V. Capacitance should be imho as large as you could find in these rice length, blocky smd capacitors that would fit easily. This (along with the already present diode on the track supply) upgrades your circuit to fully Tomix CL compatible. ps: the full circuit is: pickups - series diode - parallel cap - series resistor - led Link to comment
railsquid Posted April 25, 2016 Author Share Posted April 25, 2016 Thanks, I'll see what I can find. Link to comment
cteno4 Posted April 25, 2016 Share Posted April 25, 2016 Squid, Smd Tantalum caps can get you a lot of bang in small spaces if there is room in there on be board or you could wire them with short leads. http://www.ebay.com/itm/5pcs-7343-SMD-Tantalum-Capacitor-25V-100UF-Type-D-Accuracy-20-/191190174303?hash=item2c83d28a5f:g:EuYAAOSw-jhT--56 Jeff Link to comment
