Sign in to follow this
bikkuri bahn
Installation of electrical equipment for Hokkaido Shinkansen
bikkuri bahn
With the opening of the line a few days away, an interesting short documentary/commercial by Meiden Corporation, which manufactures all the transformers and electrical substations for shinkansen lines. The first segment is the installation of a transformer inside the Seikan Tunnel. Later we see the substation at Shin Hakodate.
Edited by bikkuri bahn
Share this post
Link to post
maihama eki
I like the little work train at the beginning.  What is that little snow plow/loco thing?
Share this post
Link to post
kvp
It's the same small work train that is available on HS, just someone bolted a plow over its hood.
Share this post
Link to post
maihama eki
It does look a little like the Greenmax kit with a plow.  Sounds like a fun project.
Share this post
Link to post
cteno4
yes looks like a fun project. sort of looks like it might fall over on its nose with the big plow and the tiny loco.
The plow would be a great 3D part to print along with a tiny crane for the little green max locos. (hint hint tony)
Edited by cteno4
Share this post
Link to post
kvp
The trick is that the plow partially goes around the motor so its center of gravity is between the axles.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Reply to this topic...
×   Pasted as rich text.   Restore formatting
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
